Winchester (026196062448) (20 - 60x70 mm) Logo
Posted on Jul 30, 2010
Question below I have a Winchester 20 gauge model 12 serial number 620502. Can you tell me the year it was made and its approximate worth. I would say its rating is at about 90% if not higher.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 07, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
149
Points
1930 where 26,262 were made. http://www.mchenry-sc.org/Engineering/Model_12.htm
  • Anonymous Feb 07, 2011
    worth maybe $400
2answers
What year was Winchester Model 70 G2585278 made?
1964
Winchester model 70s in 1964 started with sn 700, one has been fired but need to 36699. 06, 12 serial number 1 - 20 guage for models which have a 5 digit serial number can anyone tell me what year. Date manufactured in advance, made a pre-64 model 70 is this ramp because of manufacture by serial numbers prior.Feb 5, 2019
Mar 28, 2019 • Firearms
1helpful
Can you tell me the year my Winchester Model 94 32 special was made? The serial number is 1380891. Thank-you
Mark, I'm not sure if you ever got your answer in all of that above but just in case you didn't....yours is in the war years 1944, or 45. Winchester kept no records of public serials those years because pretty much all of their manufacturing went to the war effort. Simply no record keeping. In 1942, #1221289, was sold. 43, 44, 45, 46, and 47 there were no records. In 1948 they began again at the number 1500000. You can't get any accurate to the day date on yours but if you divide those numbers by the five years you get approx 55,700 a year. So 1221289 + 55700 is approx 1277000. Add another 55700 and you get approximately late 1944 to early 45 for your rifle. I hope that helps.
Feb 29, 2016 • Optics
1helpful
How old to the date is a Winchester Model 12 12 gauge shotgun with serial # 80799 ?
Your model 12 was made sometime in 1915 probably early first quarter as Winchester site states that 1914 ended with serial no 79765 for the model 12
Mar 15, 2015 • Optics
What is my winchester shotgun worth? serial#217395
Need to know more info. What gauge is it? What model is it?
Nov 03, 2014 • Optics
When was my winchester model 12 16ga shotgun serial#787927 manfactured?
Nicknamed, the Perfect Repeater at its introduction, this shotgun se tthe standard for pump action shotguns throughout its fifty one (51) year high rate manufacture and production life. From 1912 until the shotgun was first discontinued by Winchester in 1963, nearly two million Model 12 shotguns were manufactured and produced in various barrel lengths and grades. Initially the M12 was chambered strictly for 20 gauge, however 12 and 16 gauge versions came out in or around 1914, and the 28 gauge version of the Winchester Model 12 came out in 1934. A .410 version was never produced; instead, a stripped down variation of the Model 12, commonly known as the Model 42, was derived directly from scaled drawings of the model 12 and produced instead. The year of manufacture for serial number 787927 is 1939. hope this helps! im pretty sure that this is right. check it out on the web.
Top Winchester Optics Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Thomas Perkins
Thomas Perkins
Are you a Winchester Optic Expert? Answer questions, earn points and help others
