Hi, Lg Xenon GR500 cell phone`s touch screen is black it still works.these are usually caused by the flex of the phone.
The flex of the phone is located inside the phone, it controls the functions of the screen an also the keypads of the phone.
The flex is a thread like object that is located inside the phone. To see the flex, you will need to disassemble the phone to get to the flex of the phone.
After replacing the phone flex, your done.
Also it might be the screen of the phone. But in other to know if it's the screen, you will need to test a new flex.
You can get a replacement flex from any of the phone repair stores around you.
if the screen is totally black then you can pull the battery out of the phone with the phone turned on (if the keypad is still lighting up you know the phone is on) as a hard reset on the phone. if the issue still persists the issue is within the software of the device and you would want to call your provider and see if you have a warranty on the device, if there is no warranty you would want to eather get an insurance replacement or an upgrade
i had the same problem...this is what you do. u check to see if you have a magnetic phone case or if ur phone has been exposed to any magnets. idk why but magnets mess up the screen rotation. all u have to do is take a magnet and pass over the phone once and it should go back to normal. but dont ever expose the phone to any magnets.
hope this helps
i got the lg xenon for christmas.. and everytime you turn it off and power it back on you have to do the touch calibration and you do it once exaclty in the center of the cross and then any other time it asks just put dots randomly anywere and when it says save press no .. so you will have the first good calibration saved (:
did you get it wet? if so try leaving it near a heat source for a week. like an oven, dashboard of car.... I have dropped my phone in the toilet and brought it back from the dead.
I had the same problem what is causing it is the phone is trying to keep up with all the actions try waiting till the message sends completely before closing also sending massive amounts of info in a message can do this what I did to fix it was keep my inbox empty and it hasn't done it since
