The watch has recently been set to beep on the hour every hour by mistake. Now we cant find a button or combination of buttons to switch it off. Any help would be greatly received.
Push and hold the reset button on the bottom right of the watch and then push the mode button on the bottom left. When you push the mode button, all the days of thge week should no longer be illuminated. This is the same to turn the beep on, only you need to see the days of the week on not off.
To turn off the hourly beep on a Mingrui sports watch, you can try the following steps:
Press and hold the "Mode" button until the watch enters the settings menu.
Use the "Adjust" button to navigate to the "Beep" or "Alarm" option.
Press the "Adjust" button to turn off the hourly beep.
Press the "Mode" button to exit the settings menu.
Please note that these steps may vary depending on the specific model of Mingrui sports watch you have. It's recommended to refer to the user manual for your specific watch for detailed instructions.
often this is a setting on the watch face. in my experience it is a bell looking object. for most sport watches, pressing a combination of the start and stop buttons will effect this setting. More Detail on the particular watch and i can be of more help
Go to http://www.nike.com/timing/ and select your watch range from the drop down menu that is revealed when you click on "find a manual for your model"
this is usually done by pressing two of the buttons together, I cant say which two, but you can try combinations. The watch should give a short beep when successful
To turn off the hourly beep: While holding the lap/reset button down, press the mode button. When all 7 day flags show, the hourly chime is on. When no day flags show, the chime is off.
