Nordic Track NordicTrack Elite zi Treadmill Logo
Posted on Aug 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nordic Track Elite Pro 9500 is 1 month old and when you press "Start" on the console, the belt runs EXTREMELY FAST immediately, then it basically goes to zero miles per hour. The console is still lit up, but treadmill doesn't work.
Anonymous
Level 2:
  • Expert 218 Answers
  • Posted on Aug 11, 2010
Anonymous
Expert
Level 2:
Answers
218
Questions
0
Helped
101256
Points
358
The motor controller needs replaced
Nordic Track T12 si , belt won't run
If the belt on your Nordic Track T12 si treadmill is not running even though the display and other functions appear to be working, there are a few troubleshooting steps you can try:
  1. Check the safety key: Ensure that the safety key is properly inserted into the console. The treadmill will not operate if the safety key is not securely in place.
  2. Reset the treadmill: Turn off the treadmill and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on. This can help reset the treadmill's internal systems and may resolve any temporary issues.
  3. Calibrate the incline: If you recently used the incline function, it's possible that the calibration of the incline mechanism is off. Consult the user manual for instructions on how to calibrate the incline. This process may vary depending on the specific model of your treadmill.
  4. Check the motor and drive belt: Inspect the motor and drive belt for any signs of damage or wear. If the drive belt is loose or worn out, it may prevent the belt from moving properly. If necessary, consult the user manual or contact Nordic Track customer support for guidance on inspecting and adjusting the motor and drive belt.
  5. Lubricate the belt: Insufficient lubrication can cause the belt to stick or not move smoothly. Refer to the user manual for instructions on how to properly lubricate the treadmill belt. Use a silicone-based lubricant recommended by the manufacturer.
  6. Contact customer support: If none of the above steps resolve the issue, it is advisable to reach out to Nordic Track's customer support. Provide them with detailed information about the problem and any troubleshooting steps you have already taken. They will be able to offer further assistance, including potential repair options or guidance from a technician.
Damaged sd card
Call them back and get a new SD.
Reboot Reinstall Android
You need a new touchscreen, possibly a new console. See if they will cover it under warranty.
9500 pro
see the video and lube the deck belt+rollers bearing. You must do it every 150miles aprox.
God bless you
Google Maps not working on a Nordic Track Elite 9500 Pro treadmill
You must reset the Software and test the internet is working the wi-fi, test the antivirus program or malware . Run too the scan disk, and defragment the unit.finally Restore to some date that machine was working good.
Happy new Year,God bless you
Heart rate shows up on screen even though not touching sensors. When heart rate is displayed cannot access anything else on screen
proper grounding the machine mite help. the frames are powder coated and they dont remove enough paint for a good ground point chek and make better contactwith frame
3 days old and when I push any of the buttons that are supposed to cause belt to start moving or to change incline there in no response, though the electronic display starts counting the seconds as if it...
The single most cause of no motor output is failure of the DC motor control Look for any test lights on the power boards beneath the motor shroud use caution when removing the motor hood because you may still have electricity in the motor area even if the treadmill is unplugged.
One of the lights should be labeled PWM when hitting the start button that will start flickering , because the upper console is sending a signal to the lower board telling it to start the motor. if that process happens then you need to check the motor
Cordless drill battery- get a fully-charged, 18 volt (preferred) cordless drill battery and on most treadmills connect the red and black motor leads to the battery (some have different colors but if you have two wires and get it hooked up backwards, the motor will just run backwards and won’t be harmed). If good, the motor should operate at about 1 MPH.
Car battery- these are 12VDC high amp batteries so the motor will turn slowly but you can walk on the belt. Always be careful with battery acid on these things so we don’t recommend bringing them in the house…take the treadmill to the battery. If does move then the controller board needs to be replace.
Top Nordic Track Exercise & Fitness Experts
ZJ Limited
ZJ Limited
vince
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
