Music Logo
Posted on Aug 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a clp300 sticky keys - Yamaha Music
Fred Yearian
Level 3:
  • Yamaha Master 5,603 Answers
  • Posted on Aug 03, 2010
Fred Yearian
Yamaha Master
Level 3:
Answers
5603
Questions
Helped
2247545
Points
16162
Not sure what you mean by sticky... If sticky to the touch, clean them carefully with a soft cloth wetted with Windex and then dry with dry cloth.
If the keys stick down, check if there is clearance from the board in front of them. If they are dragging here, you may need to have the keyboard adjusted to have adequate cleance. This is not an uncommon problem that can happen due to warping or humidity and temperature changes.
Drag a business card between the front of the keys and the front rail to check for clearance.
How can I repair a lifted key?
If it's an ivory piano key just clean it a bit underneath with sand paper then glue it down with aquadhere and sticky tape until set.
Mar 29, 2016 • Music
How to unStick Keys onYamaha YDP121 Piano
use wd 40 and a soft clothe apply on the sticky areas give it time and clean after .
I have a key that sticks really bad...how do I fix it?
carefully remove the cover of your ypt-320 and also remove the sticky key to check the rubber pad under it .try replacing it.
1helpful
Clavinova clp300
The two leads that interrupt the signal to the speakers when the jack is plugged stay open. You'll need to open the unit and inspect to see if they are bent away from each other.3f916116-d1fa-425d-94d7-b23c6cc2e6be.jpg
Oct 31, 2013 • Music
Sticky piano key
If the keys feel sticky, clean gently with soft cloth wetted with Windex. If you mean the keys stick down we have no idea of what brand or type of piano you have and there is no way we can help you without more information.
Apr 09, 2011 • Music
Sticky keys
Sticky keys on what?
Jan 31, 2011 • Music
3helpful
My Yamaha YDP-121 digital piano has a key that is slow to pop up once pressed...the key will still produce a sound but the key becomes "sticky" and stays pressed, sometimes requiring manually lifting the...
Check if it might be dragging on the edge of the case. The restoring force for some of these comes from a silicone rubber dome that is oart of the contact. SOMETIMES the dome fails.
1helpful
Korg C-3500 Piano Sticky keys and lubricant
Hi. I saw this looking for info on the C3500 of which I own one myself. I don't know the answer to your question but I found a site where you may buy a downloadable c350 service manual for $45. Go here, http://www.musicparts.com/products.asp?Company=Korg.
Regards,
/Mats Rahm
Sweden.
Dec 11, 2008 • Korg Music
2helpful
Sticky Keys for Yamaha Digital Piano YDP-121
have you tried using the can of air. you can get it at almost any drug store walmart or kmart. just spray the can of air between the keys and they should become unstuck.
Top Yamaha Music Experts
Paul Bade
Are you a Yamaha Music Expert? Answer questions, earn points and help others
