Pure Digital Flip Video Ultra Camcorder Logo
Posted on Dec 30, 2017
Camera storage problems
My Flip HD ultra video camcorder says i have 1 hour and 22 minutes left to record, when it should have 2 hours in total (120 minutes) the camera is completely empty i checked the file and everything nothing is on the camera or in any files. COMPLETELY EMPTY! how come it says that?
-Amy MCabe
Man Ana
Level 1:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 55 Answers
  • Posted on Jan 03, 2018
Man Ana
Contributor
Level 1:
Cheetah:
Answers
55
Questions
0
Helped
16639
Points
83
Maybe you still dont unlock that, just change to unlock for opening files or etc
2 Related Answers
Anonymous
  • Posted on Jun 10, 2010
SOURCE: Flip Video Ultra Camcorder: After I downloaded my last videos my camera stoppe...
Remove the battery. Connect the camcorder to the computer's USB port. The computer will show the autostart menu or give a beep. Insert the battery now. Use the 'Safely Remove Hardware' option, stop the device and remove the Camcorder from the Computer. Close the battery compartment. Bingo! The device works :-)
Anonymous
  • Posted on Jul 28, 2010
SOURCE: Flip Ultra HD - conflicting storage info
connect your flip cam to your computer.openo c drive on your computer.open flip program.look for trash file.empty it.that will restore your full 2hr record time
3helpful
2answers
Have a new Ultra HD Flip Video. How do I know when it is fully charged? Does the red light go off or what?
Hello there,
The Flip Ultra should have a rechargeable AA battery pack.
To verify it is charging, the battery icon will be flashing lightning bolt. The red light goes from red to green the moment it is fully charged. It takes six hours before it gets a full charge via the USB.
Please let me know if this gave you enough information. Thank you for using FixYa.
Hi I have a Flip Ultra Video. When it says I still have 1 hour 23 mins of recording time the camera shuts down. Battery?? I plug it in to charge and after that it says I have over an hour left of...
1) Put your Flip Ultra back into the pakaging box
2) Keep it safely inside your fridge (make sure the fridge isnt on or the best is an old fridge model)
3) Scratch your head and scratch your nuts in the same time for thirty second
4) Turn on your Flip camera, press the red button for setting, and change it to indonesian language. If no indonesian language in the setting, shake it 3 times. It surely has.
5) Jumping around on your parent bed.
6) Sing Britney Spears song and film it yourself.
7) Press stop button
8) Post it on youtube.
I hope this will fix ya problem. Have a nice day :)
7helpful
1helpful
2answers
8helpful
3answers
I cleared all the files on my Flip camera and all the files are deleted but the amount of memory is not going back to 60 minutes it is now at 35 minutes
ok, this totally helped w/ mine, I have a 120 ultra and it made my remaining recording time to back to the original time, thanks a bunch YD CORP !!
3helpful
4answers
Flip Ultra HD red light won't turn off after charging. Camera won't do anything at all. What do I do?
UNIT: ultraHD
PROBLEM:
I just had this problem: I turned it on, started to record a video, but it hung up on frame #1, with the record red light stuck on. And I couldn't do any of the following: restart the recording, play already recorded videos, turn it off, connect to PC.
SOLUTION:
I removed the battery for about 30 seconds, then replaced it. my UltraHD flip works great now.
1helpful
Camera software corrupted??
I had the same problem with my flip mino HD. Here are the steps I took to fix it.
1. Adjust the power options on your laptop to ensure it does not sleep/hiberate ever.
2. Reset the camcorder by inserting a paperclip into the hole in the tripod mount. Hold the paperclip in there for about seven seconds.
3. Then immediately plug the flip into the cpu.
4. You may not see anything besides the little blinking white light on the USB arm for a while (about 30 minutes maybe) but leave it in.
5. Eventually it should spring to life and show the recharging battery on the little screen (the Flip Share program may start too.)
6. Leave it charging until the little white light stops flashing - full charge about 3 hours.
7. You can then remove the flip and change the power settings back to normal.
38helpful
6answers
To regain record time we are told to re-format the flip video ult
I had the same problem so I tried the thing on the website and it didn't work so I looked it up on Youtube and someone figured out how to do it. I tried it and I got all 60 minutes back. You should try this, it probably works.
PS instead of 5 nines it's 6 nines.
2helpful
Frozen on startup
Take out the battery and leave it out for 48-72 hours. I had the same problem and Flip support suggested this solution which fixed the problem.
Top Pure Digital Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Tony Parsons
Tony Parsons
Are you a Pure Digital Video Camera Expert? Answer questions, earn points and help others
