Has anyone ever replaced a front cover assembly on a Kodak Z612? I have the part but I haven't attempted to take apart my camera yet. Any advice? How hard is it?
Thanks!
Remove all straps and battery. remove the 6.1 side plate there are 2 screws under plate 3 on bottom 1 in usb 1 above lcd . remove usb housing . gently pull up on bottom by dock adapter to clear plug then cover should pull off . then remove lcd gently remove clasp that hold lcd ribon . under lcd there is three screws pop flash up slide housing off . battery door must be open to remove rear housing.
