Maximum of 1 GB per slot.
Yes, you can buy DDR400, it will be underclocked by the motherboard to DDR266. If you want some extra performance you can go in the BIOS and lower the timings one unit.
Yes, they will work, but not very fast. They should be used only as a last option.
Testimonial: "gud but i need a bit clarification for terminologies and methods he said."
underclocked - the components is run at a lower speed than its default one - the opposite of overclocked.
For example if you would install DDR400 they will be automatically run at DDR266 speeds, the maximum your motherboard is capable
These are the timings http://www.hardwaresecrets.com/article/2... they are defined and modifiable in the BIOS. On an average DDR400 stick they are 4 - 4 - 4 - 8
Since you are underclocking they can be lowered to 3 - 3 - 3 - 7 or even lower , to 2 - 2 - 2 - 6.
can u please clarify me what is meant by "UNDERCLOCKED"? would the ram not work at its peak ? for instance if i install 1 gb 400 mhz per slot (totalling 2 gb) wouldnt they work at there peak and give me the best and quicker performance which they should do and intended to do?
and how can i lower the timings one unit? please clarify these i shall be thankful to u...
