The reasons for the "No disc" issue are various. In order to solve the problem more precisely, you can refer to the followings reasons and select the most solutions.
1. Incomplete disc information or scratched disc. This is the main reason for the issue. Before you try anything to examine or fix your DVD player, it's suggested that you make sure the disc you are trying to play is intact and well. If it's the problem of your disc, then trying to fix your DVD player does not help at all. In this case, you can copy the scratched DVD disc and then you may play it on your player machine.
For more information and solutions to this problem, you can check this guide.
Guide: How to fix a DVD "No disc" error (3 solutions)
I have recorded on DVD-R many times.
Blank DVD-R.
No, mine does take DVD-R, I tried DVD+R & nothing.
Now my player wont Record.
Wont power up & take in Blank discs.
I have the same model ... you can't use DVD-R or DVD-RW discs, only DVD+R or DVD+RW
dvr cyber home 1600 will not read the **** , says no disk , but after edject disk afew times will play
When I was on holiday in California (USA) I bought this DVD Recorder and had trouble trying to record with the messages ' Disc Error/No Disc'.
In India I still have the Trouble and am unable to use the DVR1600.
I took it to a mechanic who says it is a 'Software Problem' - I wonder what it is and how do I solve it. Any solutions?.
l have the same problem, with my DVR 1200,some time by opening and closing the DVD I can get it to start to play, whats the solution?
Ron
