Question about Sharp AR-5316 Advanced Digital Imager Copier
Sharp ar 5516 printers error h5. h4 - Sharp AR-5316 Advanced Digital Imager Copier
  • dady3
    dady3 Dec 17, 2013
    photocopie sharp ar-5620n code h5 help me please
  • Mathieu Djafsia
    Mathieu Djafsia Jan 27, 2017
    bonsoir comment faire lorsque ma photocopieuse affiche h5 ?
    New Friend:
Hi,I have error code L h on my coppier sharp 5516. your help please.
Posted on Aug 25, 2010
  • sumithkaru Nov 25, 2010
    indicate display '' 2'' and ''F'' message
After you pressing C-Int-#-int then press digit 14 and press start botton.
Posted on May 10, 2012
  • 2 more comments
  • satish gautam Oct 08, 2013
    have problem with copier make sharp model AR 5516 D. giving error messege H5 or h4.
  • chiboy
    chiboy Jul 10, 2014
    help me im to far for the text iam only fixing my machine any idea how to fix ser?
  • Laxmi Kanta Kandel
    Laxmi Kanta Kandel Nov 11, 2014
    have problem with copier make sharp model AR 5516 D. giving error messege h4.
    C-Int-#-int means
    New Friend:
I have problem with copier make sharp model 5516.
giving error messege 4h or h4.
pls give me solution.
thank u
Posted on Jun 07, 2013
  • 2 more comments
  • earthian_dha Dec 08, 2013
    For Sharp AF5516 if error message is 4H than press #,intercept,c,intercept and enter 14 digit and finally press start button. This will solve h4 problem
  • chiboy
    chiboy Jul 10, 2014
    hi iam to far for the technician any idea can i fix H4
    hi iam to far for the technician any idea can i fix H4 in Sharp AR 5516 D
  • Full Name Feb 26, 2017
    can anyone help me correct error code E7 10 on AR 5516S sharp
  • Sharp Expert
  • 318 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} H4 Heat roller low temperature detection
reset code 14
H5 paper jam in heater unit
Posted on Aug 07, 2010
    New Friend:
    Problem Solver:
  • 4 Answers
Posted on Dec 08, 2013
  • PRATAP KUMAR DHAL SAMANTA
    this message is help to me to function my machine
    New Friend:
H4 0
Posted on Jul 13, 2014
6ya staff
SOURCE:
My Printer is displaying an H4 error
The error code H4 means that you have a problem with the fixing unit. It could one of the item's > The thirmistor or thermal fuse or the fixing heater lamp
Oct 05, 2012 | Sharp Office Equipment & Supplies
The printer Ar-5516 is showing H4 error
this error means:
heat roller abnormally low temperature.
for check:
1- check the heater lamp
2- check the thermistor
for reset:
clear key --> interrupt key --> "0" key --> interrupt key --> 14 --> start key
Jul 04, 2012 | Sharp AR-5316 Advanced Digital Imager...
Ma photocopieur shar 5516 marque un message d'erreur H4
H4 error indicates the fuser is faulty and should be replaced.
Jun 19, 2011 | Sharp AR-5316 Advanced Digital Imager...
Problem for Sharp AR-5320 Black and White Copier Ar 5516 display H4 error?
for AR 5320 just check 1- main corona 2- leveling the developer unit 3- clean cleaning plate,
for H4 just rest the machine as mentioned above, if not plz check fuzing unit -- thermostat
Aug 22, 2010 | Sharp AR-5320 Black and White Copier
I have a sharp photocopier AR-5316 flashing error code is h4 how to reset this code and solve the problem
i have a sharp photocopier AR-5316 flashing error code is E7 how to reset this code and solve the problem
Jul 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Oct 26, 2008 | Sharp AR-M160 Laser Printer
Ar-c160
Make sure there is no paper jammed in machine, H5-01 means 5 jams same location. Use quality paper not recycled and make sure it is fresh not old stock
PROGRAM INTERUPT CLEAR INTERRUPT must be SUPER FAST then 14....WILL RESET CODE
Dec 16, 2007 | Sharp AR-C160 Color Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
9,251 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
