Olympus Mju Tough 8000 Compact Digital Camera Logo
Posted on Aug 05, 2010
My olympus tough 3000 will not turn on, when i turn on orange light at the top just stays on but nothing comes up on the screen
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 02, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
919
Points
.' i have a problem with my camera olympus u tough 3000, when i turn it on..it is okay but after 4 or 5 seconds it will automatically shut off.. help me please... if what should i do.. what is the best solution to fix this..
4 Related Answers
Anonymous
  • 11967 Answers
  • Posted on Oct 16, 2010
SOURCE: Our Olympus 7010 has gotten the lens stuck out,
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Testimonial: "Fix#7 worked. Thanks so much!"
A
Anonymous
  • Posted on Jun 30, 2008
SOURCE: olympus fe-210 fault
Remove the memory card and batteries. Let the camera sit for a few seconds and reset. Replace the batteries, but not the memory card, and turn the camera on. That should fix the lens problem.
Anonymous
  • 82 Answers
  • Posted on Dec 29, 2008
SOURCE: olympus fe-340 doesnt stay on
go get duracell rechargeble the green one digital camera need powerfull battery let me khow
Anonymous
  • 6831 Answers
  • Posted on Nov 28, 2010
SOURCE: Olympus FE 4000 camera, pretty
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Olympus stylus 7040 turns on but doesn't work at all
Try removing the battery then put them back and check if this will resolve the problem.
1helpful
Olympus stylus tough 3000 digital camera my screen is white
Sound like a CCD sensoir problem, this job will need solve in the repait shop.
1helpful
1helpful
I have an olympus u tough 3000 which wont charge - any ideas?
Try a different battery. Also, try a different cable. Try a different USB port on the computer.
How do i get rid of the no connection on the screen ?
Here is a tip that I wrote about how to find the manuals, drivers, downloads and support for Digital Cameras.
Digital Camera Manuals, Drivers, Downloads, and Support
heatman101
I can't figure out how to open the battery compartment on the Olympus tough 3000
Here's what to do:
  1. Make sure the lock is slid all the way to the left.
  2. Pull it down. The compartment should pop open.
  3. Now, slide the battery lever down, and the battery should pop right out!
Thanks for using FixYa!
Hi, We gave my mum a new tough 3000 Olympus camera and we are unable to download the photos from the camera onto her pc. We have plugged the cord into both the USB port and the camera but nothing...
Hi Fiona
When you connect the camera to your computer with a usb cable if you click on 'start' at the bottom left of your screen and the click 'my computer' .
The window that opens will show all the drives connected to you computer eg your hard drive (usually c: ) and your cd/dvd . If you open the other drives one will have all the pictures in .
Then just select them all by selecting 'edit' then 'select all' at the top left of the open window and then click 'edit' and 'cut '.
If you then open My documents and open the folder 'my pictures' ,then click 'edit' and then 'paste' at the top left of the window all your pictures will be copied to that folder.
Just to make it easier the camera will have come with a cd ,if you put that in the cd drive it will offer to install software ,if you accept and install it every time you plug the camera into the computer it will start the program and copy the pictures automatically.
Hope this helped
Alistair
2answers
Laptop wont turn on at all!
try sensing if your cpu fan is working, it is under the power switch side, you can see small exhaust slots, put your hand beside it and feel if some air is coming out when you turn on your pc.
When you turn you pc on and only orange light blinks, it means that no power was getting into it, it blinks because no electrical power is coming from your power adapter and the battery is drained. Check your power adapter cable, this is the very cause why your pc is shutting down. usually the wire from the adapter to the pc is faulty.
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
