Bad tasting ice from amana freezer - automatic ice maker - have water filter under sink in line to fridge - new filter installed - drinking water fine - ice still tastes of minerals - looks like mineral build-up on inside of ice making tray. What to do?
I have the same issue with my Samsung fridge. Water tastes fine, but the ice has a bitter chemical taste - as if there was dishwasher detergent residue in the cup. All the water lines are plastic, I've changed the filter three times in the last four months, I've cleaned out the ice maker and the fridge and even replaced the bin and the ice maker itself and still have nasty ice. We still use the water from the fridge door dispenser but we buy ice. Makes me wonder why we got such an expensive refrigerator!
Sometimes filters have issues like this even being new , it is located at the bottom kickplate [round] , pick up a new filter -part number 4396841 - install the filter , dump remaining ice in bin out , purge the water through the new filter through water in door for a few minutes and you should be good.
Phil
Hi!! change your copper line going to the icemaker and also install a water line filter you can buy one at homedepot easy to install and has instructions on how to...good luck..
then change your filter. the new filter could be different with the old filter. check the new filter, see if there is odor removal and taste removal with it.
if not then get the filter with carbon filter, odor and taste removal.
then with a new filter, run about 5 gallons of water before using the water for drinking.
You said, Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You
replaced the copper tubing which delivers the water to the fridge and
that didn't help. You replaced the copper tubing again with plastic
tubing...no better. Any suggestions? Your tap water doesn't taste this
bad.You bought a Kenmore french door fridge with water dispenser in the
door in July 2008. The fridge has a filter. A few weeks after the
fridge came the water and ice started tasting really bad, unlike any
bad water taste I have ever tasted. And your tap water is fine. The bad
taste appears to be random. Sometimes you get a cup full of nasty water
and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions! Did you do this before connecting the water line to your fridge? "Place the free end of the tubing in a container or sink, and turn ON the main water supply. Flush the tubing until water is clear. Turn OFF the shutoff valve on the water pipe. Coil the copper tubing."
Whirlpool remedy Off-taste, odor or gray color in the ice 1.Are the plumbing connections new, causing discolored or off-flavored ice? Discard the first few batches of ice. 2.Have the ice cubes been stored too long? Throw old ice away and make a new supply. 3.Does the freezer and ice storage bin need to be cleaned? See “Cleaning” or “Ice Maker and Storage Bin.” 4.Has food in the freezer or refrigerator been wrapped properly? Use airtight, moisture-proof packaging to help prevent odor transfer to stored food. 5.Does the water contain minerals (such as sulfur)? A filter may need to be installed to remove the minerals. 6. Is there a water filter installed on the refrigerator? Gray or dark discoloration in ice indicates that the water filtration system needs additional flushing. Run additional water through the water dispenser to flush the water filtration system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to 7 minutes initially). Discard discolored ice. Let me know what works, Thank You , HUUUM!!
Our refridgerator has terrible tasting ice and water and we have tried everything to fix it. Is there a sure fire way to fix the problem. I would love to use the ice maker and water.
miracow
Bad taste ice
