Sony DAV-S300 System Logo
Posted on Aug 06, 2010
I bought an I cinema i-HD901 system and it does not have any power cord. All there it has are wires. what do I used- to power the speakers and the subwoofer. I would like to be able to play this surround system through my TV. It only came with 5 wires is that enough?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 05, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2707
Points
You .need a 5.1 reciever. Run the sub and speakers to the reciever run the reciver to your cable or tv
I need help at a system home cinema
probook 470 G1)
the PC has only 1 jack for output. called line out /phones.
sadly I can not guess what this home cinema system is at all
no makers name of
home cinema no model name or numbers for home Cinema
so no answers possible
speaker system with built in power audio AMP is needed.
The below 6 are called CONNECTIONS
  1. USB system ,
  2. or fiber. TOSLINK.
  3. or 3.5mm line out jack call "Phones" jack tool (or 5.1 Surround)
  4. or wifi sound
  5. or Blu-tooth sound.
  6. coax S/PDIF
your PC can not drive directly any wired speakers.
https://www.pcdied.com/no-sound/speaker-neat.jpg
wired means 2 wires to the raw speaker cone coils..
it needs to have an amplifier to the raw speakers.
no home CineMA, TOLD NAME OR MODEL OF PHOTOS OF IT Present.
just buy USB sound BAR at Wal-Mart and be happy?
plug it in see it works.
to do 5.1 with 3.5mm color jacks that you do not have
you need 5.1 sound USB dongle.
https://en.wikipedia.org/wiki/Surround_sound
here is 7.1 via USB
https://www.amazon.com/Vantec-NBA-200U-External-Channel-Adapter/dp/B004HXGJ3S/ref=sr_1_6?crid=3IOQB60XVZ9RO&keywords=usb%2Bsurround%2Bsound%2B5.1%2Bdongle&qid=1651230452&s=electronics&sprefix=usb%2Bsurround%2Bsound%2B5.1%2Bdongle%2Celectronics%2C146&sr=1-6&th=1
I don't know how to hook up my i cinema i-hd901 i don't have the amplifier and don't have a flat tv could you help me please!!!!!!!!!!!!!
I bought a cinema HD 901 home theater system. How would I hook that up? Do I need to buy a 5.1 receiver? Because there's no power supply on subwoofer how many watts do I need on my 5.1 receiver if I have to buy one
5helpful
6helpful
2answers
I received an I-HD901 surround system. How do I hook it up directly to my Sony tv and do I need to buy a receiver or an amplifier?
DON'T NEED A SEPERATE AMP THE SYSTEM HAS ONE IT IS PART OF THE CABINET THE DVD PLAYER IS IN, YOU CAN HOOK IT TO THE TV WITH A HDMI CABLE OR STANDARD VIDEO CABLE OR A PROGRESSIVE SCAN CABLE SETUP, FOR AUDIO U CAN USE STANDARD RCA CABLES, OR DIGITAL AUDIO, CHECK TO TO SEE WHAT OUTPUTS AND INPUTS THE TV G THE TV HAS ALSO CONSULT YOUR USER MANUAL FOR THE SURROUND SOUND. HERE ARE THE SPECS FOR THIS SYSTEM.
1000 WATT system total program power
5.1 Cube cinema HTS, 12 active drivers/magnetically shielded
I-Cube design satellite system
4 Multi-directional 2-way speakers()
center channel has 2-way with horn tweeter enclosure (200 WATTS)
Dual sub-woofers 400 WATTS; 2X6.5" aluminum poly-laminate cone
linked through digital custom crossover circuitry finished in: high-gloss piano and composite black w/silver brushed aluminum
complete 6 piece system (HTS surround speakers
Protection displayed and shuts off When I press the power button Protection is appear on screen on my home cinema system dvd player
check wiring on speakers it sounds like you have some wires touching together somewhere or you have a bad speaker.
Wireless speakers
Google "Samsung SWA-4000" The HTz310 is wireless "ready" only. You'll need to purchase this unit for about $100 to make your (Rears only) wireless.
Can't get tv sound from home cinema system speakers
you need an optical cable going from the TV to the home cinema for an audio output, it worked for, had the same problem!!
JVC THR1 DVD Digital home cinema system.
There is other Cinema Surround systems that use the same 8 Pin setup Aldis had one retailing at £49.99 and there are plenty on E-Bay www.eserviceinfo.com will provide schematics for these systems so you can select the right one.
2answers
Buzzing in speakers of cinema surround
i have the same problem. haven't tried the fix yet, but someone recommend connecting the two pronged power cord to an adapter that switches it to a 3 pronged (adds the ground prong). i guess the adapters are less than a dollar and can be bought at most places.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
