Question about HP PSC 1610 All-In-One InkJet Printer
My HP PSC 1610 All-IN-ONE will not read SD-cards. We have had this problem in the past and now that my son's birthday came, I cannot upload pictures to my computer.
  • HP Master
  • 12,061 Answers
Please try unplugging the Printers USB cable reboot the PC, and after it is at desktop, THEN plug in the printer, Now it should work OK, Also Try ANOTHER USB port too.
If that doesn't work, again unplug the printer and reinstall the drivers from the DVD. etc. Now try again. If it still doesn't work, perhaps it is the SD card? In fact, I guess FIRST you should check that SD card and see if it can actually be read?
Posted on Aug 08, 2010
6ya staff
SOURCE:
Have a nikon coolpix S8100 with a 4gb card. My hp photosmart 7960 reads "error reading card" when trying to upload pictures. I have no problems uploading my old memory card from my cannon A95.
The 7960 works with SD cards. It does not work with SDHC cards such as your 4GB card.
SD cards max out at 2GB. While SDHC cards are physically identical, they are electronically incompatible and will not work in devices not designed for them.
Sep 11, 2011 | Nikon S8100 Digital Camera
The 2355 gives an error when I plug in a SD/SDHC Memory card, it won't read it.
Your HP all-in-one can read the following memory cards: CompactFlash (I, II), Memory Sticks, MultiMediaCard (MMC), Secure Digital, SmartMedia, and xD-Picture Card. Note: It will not read an SDHC.
Jan 21, 2011 | HP PSC 2355 All-In-One InkJet Printer
I have a HP PSC 1610 All in one printer and I tried putting my media card in the SD slot and it tries to read the card but the red light flashes and says memory card error. HELP Please!
If using the Card Reader -
The HP all-in-one has detected an error with the memory card.
1. More than one memory card is inserted in the HP all-in-one.
2. An incompatible camera is connected through the camera port.
3. A memory card is inserted and a digital camera is connected at the same time.
Solution:
Remove and reinsert the memory card. It may be inserted incorrectly. If the problem continues, the memory card may be defective.
Remove one of the memory cards. Only one memory card can be used at a time.
Check the user guide that came with the camera to see if it supports PictBridge. If it does not, try using the cable that came with the camera to connect the camera to the USB port on the back of the HP all-in-one instead of to the HP all-in-one camera port. If the camera does support PictBridge, make sure the camera is set to PictBridge mode. See the user guide that came with the camera for instructions on how to do this.
Remove the memory card or disconnect the camera. Only one can be used at a time.
You might try the following - Reformat the memory card in the camera or format the memory card in a Windows XP computer by selecting the FAT format.
Hope this helps!
May 01, 2010 | HP PSC 1610 All-In-One InkJet Printer
When i plug an sd card into my hp 1610, the pictures are very very slow to show up on my computer screen, and when they do show up it doesn't want to print them. The copier still works fine. Is the problem...
USB ports on a computer are either:
* USB 1.1 -- up to 11 megabits/second
* USB 2.0 -- up to 20 times as fast as USB 1.1
So, be sure to connect your printer to a USB 2.0 port on your computer, to get faster file-transfer.
As to the "does not want to print", what error-message(s) are produced?
If you copy a picture to your My Pictures folder, can you right-mouse-click on the picture, and "print" from there (after removing the SD card from your printer) ?
Jan 02, 2010 | HP PSC 1610 All-In-One InkJet Printer
Card reader not working?!
Have you tried another memory card?
Some devices can read SD but not SDHC. If your memory card is 1 or 2 gig, it's SD, if it's larger, it's SDHC which is not backwards compatible with SD.
Based on the age of the PSC 1350, I would bet it's a SD-only device.
Nov 02, 2009 | HP PSC 1350 All-In-One Thermal Printer
Photo 99 ink not working with HP psc 1610
I am a very impatient person LOL... I waited 24 hours and decided to buy a whole new printer ;) PROBLEM SOLVED ;) I am very happy with my solution LOL. Thank you all who pondered over my question ;)
Jun 20, 2009 | HP PSC 1610 All-In-One InkJet Printer
Cannot get pictures off of SDHC Card 4GB
Could be it only supports SD cards up to 2gb but not SDHC.
Jun 16, 2009 | SanDisk 4GB microSD High Capacity Memory...
PHOTO CARD
It only supports SD,Compact Flash, Memory Stick and SmartMedia.
here is the manual:
http://h10032.www1.hp.com/ctg/Manual/bpu05064.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 10, 2009 | HP PSC 2210 All-In-One InkJet Printer
512 mb SD CARD
For External card reading , u have to buy one Card Reader (http://usbmanor.com/ProdInfo.aspx?prod_id=6001) to download the picture from u r SD Card ,
HOW :- attach the card reader to u r computer, & insert your SD CARD to suitable slot,,,.... Go to My computer, u will see the one more HDD drive , double click on that & open your Picture, Copy & past to your compuer.
Jul 29, 2008 | SanDisk 1GB microSD Memory Card
HP PSC 1610 All-In-One InkJet Printer Logo
85 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
