I change the fuse 3 times. Lights in the garage and out side light by the front door are not working
If the fuse is the right load for this dryer but keeps blowing then there is a sever fault in the dryer this could be in the wiring loom or more likely in the motor the dryer is pulling far to many amps and the fuse should then blow to protect the house wiring from catching "fire!"
yes i did say "fire!" so dont try up-rateing the fuse,,,,thats asking for it!
i would not use this dryer till you have it looked at,,,you will be risking a dryer or house fire if you do,,,
