Makita 12 Volt Cordless Drill/Driver Kit Logo
Posted on Aug 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Makita with 2 PA14 batteries and a DC1414F charger. When I turn the charger one the green light flashes once but no other lights show at all when I'm trying to charge my 2 batteries. Neither battery is charging so whats the fault? Batteries or charger?
Repair Ahjoshe
Level 3:
  • Makita Master 885 Answers
  • Posted on Aug 19, 2010
Repair Ahjoshe
Makita Master
Level 3:
Answers
885
Questions
0
Helped
642916
Points
2112
You stated you have a 12V Cordless Drill with PA14 batteries. The PA14 battery is 14.4V. The battery may fit in your tool and might work for a while but the motor isn't made for that battery. The way to check the batteries is to try them in another charger, any 14.4V to 18V pod/stick charger will work. The way to check the charger is to try another battery, any good 7.2v to 14.4V pod/stick battery will work. Unless the charger got wet or extremely hot the problem is usually the battery. Just check to make your tool and battery voltage is compatable.
Dc1414f charger does not work anymore how to get the charger back charging again
  • BEWARE ! In recent years, on marketing technical reasons loader print separately orderable significantly
    more expensive than a new complete charger with many brands.
  • Panasonic Festool Bosch Dewalt can have on a different base a Replacement powerprice , but sometimes most in the budget range its better to buy it complete new. its oft cheaper.
  • If On download page below the picture you see the word processing .... wait be pati?nt until there pop upped the word Get Manual underlined in stead of.
  • MAKITA DC1414F BATTERY CHARGER Service Manual free download schematics...
1helpful
4answers
My dc18ra makita battery charger flashes red and green lights no matter how many bateries i try
The pcb inside the battery has a microcontroller that monitor the charges and charge cycle. When the cell falls below a certain voltage, it will instruct the charger not to charge and will show with a red-green flashing light. If the battery has been tried 3 times in succession then the pcb will brick itself from the makita charger. So first replace the bad cells. There are 2 solutions at this moment: charge with a 3rd party lithium charger like the imax b6 or replace the pcb with a working one. check out my blog on http://mkbl1830.blogspot.com/
1helpful
Makita DC18RA Makstar Li ion Charger three lights
Alternate Red and Green flashing means bad battery. Buy a new one, or take it to a Makita Service center for replacement if it's under warranty.
Normally the yellow light indicates hot battery, but it could also mean dirty battery contacts so the heat sensor can't be read, or that the fan is clogged with dust and unable to cool the battery. The manual says let the battery cool and try again. If the yellow still flashes, it's contacts or the fan.
Read the manual online at:
http://www.makita.ca/data/upload/accessorypbim/417_im_english.pdf
4answers
I have makita bl1830 battery 18volt it works fine but will not charge, charger lights flash red and green therefore battery will not charge
If both red and green lights are flashing after you put the battery on the charger, the charger is reading the battery as bad or defective and it will not charge the battery. It may be because there is a short in the battery, one of the cells is bad or the battery is just old and won't charge anymore.
2helpful
Red and green light flashes alternatingly with only one of my batterys of my makita 18v li-ion fast charger
unplug charger to let it reset. plug back in and then try again, if it still flashes red/green that would indicate a battery failure. check for warranty replacement.
17helpful
3answers
MAKITA LXT BL1830 18V LITHIUM-ION 3.0AH BATTERY
If the charge count on the batteries is under 300, Makita will replace them. Makita has a known defect in this battery that causes the battery to shut down before it is dead. So as of now they are exchanging ones with low use.
If they are truly defective and makita won't replace, you have to open them, find the dead cell or blown fuse, and replace. Search youtube makita battery for a video on repairing this battery. But once the red and green lights on the charger flash, the the battery can't be charged on a Makita charger -- it's been locked. So use a third party charger.
4helpful
3answers
When put on charge the green and red light flash
Yep, not the batteries, mine is doing the same thing but my second charger works fine with the same batteries
1helpful
MAKITA LXT BATTERY CHARGER
hey
flashing orange=cooling abnormality.
you need to wait for the battery to cool.
see my mod page, it has all light explanations in it.
Have fun
Avi
Top Makita Drills Experts
Sean Wright
Sean Wright
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Makita Drill Expert? Answer questions, earn points and help others
