On started up my computer will not boot. It says windows XP is loading, but instead of loading all the way it stops and starts over again. It's like it is stuck in a loop.
Hi there, my name is Alex and Im here to help solve your problem.
It could be a number of problems.
1: Have you installed any new hardware or software? This can cause some conflictions. If there is any new hardware you have installed and your PC is constantly rebooting, then remove that hardware and try booting. If you have recently installed new software and getting the loop, then start windows in safe mode by pressing F8 before it boots windows. If you can access windows in safe mode, then uninstall any new software you may have added.
2: It could be you need a new power supply. They are very cheap to buy and I would recommend a qualified technician to install it for you
3: Your pc may be infected with a virus and has affected the boot file. Try to repair windows by using the windows xp disk. Insert the disk and run using the CD. You will then go through a few blue screens and press R to repair your windows xp installations
I hope this information has helped. Please let me know if you have any questions or further problems
Your xp is having problem try to repair it
Im not sure which file you are referring to but you could just a repair of the installation
this is fot the master boot record
if there are any other files , settings or programs during the repair process options for these should be available
Insert your Windows XP installation CD or recovery disc, and restart the computer.
Instead of attempting to boot Windows as it normally would, the computer will give you an option to boot from the CD.
Press a key when prompted, then wait for the setup program to load.
Press the "R" key on the "Welcome to Setup" screen.
This will cause the CD to launch the Recovery Console instead of attempting to install Windows XP on your computer.
If you have an administrator password on your copy of XP, then you will need to enter it in order to log in to the Recovery Console.
Choose the installation of Windows XP that you want to repair (generally the only option). Wait for the command prompt to appear, then enter "fixmbr." Press "y" when prompted to let the FixMBR utility overwrite the corrupted bootloader with a new copy.
Remove your XP disc or recovery disc, then type "exit" into the command prompt.
The exit command should cause the computer to reboot, allowing the computer to load the new bootloader file and then continue Windows XP startup as normal.
Hope this helps
If you are running Safe Mode because you cannot get into Windows, you may want to first try
loading the last known good configuration.
To
get into the Windows 2000 / XP Safe mode, as the computer is booting
press and hold your "F8 Key" which should bring up the "Windows Advanced
Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note:
With some computers, if you press and hold a key as the computer is
booting you will get a stuck key message. If this occurs, instead of
pressing and holding the "F8 key", tap the "F8 key" continuously until
you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode
- If after several attempts you are unable to get into Windows 2000 or
Windows XP Safe Mode as the computer is booting into Windows, turn off
your computer. When the computer is turned on the next time Windows
should notice that the computer did not successfully boot and give you
the Safe Mode screen.
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
Once
you're done in Safe mode if you want to get back into Normal Windows
restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
Microsoft Windows Vista and Windows 7 users
To
get into the Windows Vista and Windows 7 Safe Mode, as the computer is
booting press and hold your "F8 Key" which should bring up the "Windows
Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note:
With some computers if you press and hold a key as the computer is
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
due to continuos power problem wp faild to load
