I just bought the above mixer and would like to rehab it. Mechanically, I'm very proficient but I have seen the asinine Hobart policy regarding sales of technical manuals. Given that limitation, can you assist me with teardown, lube, and reassembly?
Thanks,
Tom
You should be able to purchase the manual. I know that Hobart abandoned that policy a few years back -- unless they re-instated it. Call Mother Hobart and ask. 937-332-3000
There is a few tricks to these units, it would be tough to convey here. But here goes...
Remove back cover. Loosen 6 or 7 screws around outside of motor windings. Thump the nose of the mixer downward to break the seal. Watch for spacer washers where shafts go into motor case. Remove spring. Remove idler. Remove shifting guide. Remove gear assy. Leave beveled gears in place if possible. Clean. Use Darina II grease. (20 oz) Clean and permatex "seal". Tighten mounting bolts. Adjust set screw at back of planetary. (Double set screw. The first one is to lock the adjustment.) Test in 1st and then 3rd while turning the set screw. You just make it quiet for a proper adjustment.
Good luck -- Mike
there is a condensator somewhere inside? because mine only run when i start by hand
