LG LWHD1500ER Wall/Window Air Conditioner Logo
Posted on Aug 08, 2010
Fan blows fine not blowing cool air acts like it is kicking on then just kicks in and out what could be the problem
Anonymous
Level 1:
Novelist:
Champion:
  • Contributor 266 Answers
  • Posted on Aug 08, 2010
Anonymous
Contributor
Level 1:
Novelist:
Champion:
Answers
266
Questions
Helped
50663
Points
5
Normally this is a sign of a bad compressor or a bad start capacitor. The capacitor you could do yourself if its the compressor buy a new unit. sorry
1helpful
2000 caddy Seville ...after starting and engine warm turn on the heater and it blows cold air. Fan works / waiting for hot air and then all the sudden it kicks in. Engine at normal temp
Low coolant, if there is an air pocket in the engine it will make it to the heater core. Once there , the air coming out is cold/cool. Once the coolant fills the heater core, it gets hot. If the coolant is fine hot or cold, then have the HVAC system scanned.
My ac is acting funky. my ac will blow cold air as im moving. once i stop and idle for longer than 3 or 4 minutes, something will kick on and then it will start to blow hot air. as this happens, my car...
Start by checking to make sure that the a/c condensor and radiator is not full off debris. If the condensor and radiator were full of debris it will limit the air flow from the engine cooling fan which in tern will cause a high discharge pressure on the discharge on the a/c causing poor or no cooling at idle and could also cause vehicle to overheat. Check and make sure that the cooling fan as well as the condensor fan are coming on together when the a/c is turned on if equipped with 2 fans.
Maytag m6x06f2a like new but doest blow cold air
Make sure the Thermostat is set correctly! The problem with mine was the temp in the house was colder than my A/C lowest thermostat setting.I had my AC temp setting on 66 degrees.The temp in the house was a little lower so the AC didnt kick on just the fan blowing cool air and no compressor working. The next day it was warmer out and the house temp was 79. So when I powered up the AC set at 66 i heard the compressor kick in and the AC worked fine.
I have a 2002 Dodge Ram Quad Cab 4x4. The a/c runs great as long as the truck is moving, but as soon as you come to a stop it starts blowing warm air. Please help.
Generally if the a/c works fine at highway speeds but kicks out or slowly begins to blow warmer and warmer air as the vehicle is driven at slow speeds or is stopped the a/c condensor cooling fan is usually at fault. At highway speeds there is enough air being forced through the radiator, condenser, and oil coolers to keep everything working and cool but when the vehicle is moving slowly or is parked the electric and mechanical cooling fans have to be working to pull enough air through to keep things working. If the cooling fan isn't working or can't pull enough air through the a/c condensor the system will kick out once the internal pressure reaches a certain point. Once the vehicle is moving again the system can get rid of the heat that it has gathered from the passenger cabin, the pressure drops back to normal and the system cools again. I would start by looking for a blown cooling fan fuse in the fuse panel under the hood. Usually they are 25 amps or larger and run only the cooling fan.
Weather King blows fuse in Criterion II furnace
You probably have a shorted wire between the heater and the a/c. There are two wires that conncet the control power to the outdoor a/c from the heater they should be on terminal c & y in the heater. disconect those two wires and try it again if the fuse doesnt blow you have a short in the wire between the a/c & heater
Air conditioner is not blowing cool air, but fan still blows
check the compressor with the ac running and make sure the compressor is kicking in and out in not the compressor might be bad or te clutch on te front of te compressor, sometimes u can get to much freon in them to i did it ounce
Will not cool properly.
You have either a faulty thermostat, dirty condenser and evaporator or a faulty run capacitor. Need to service soon before the compressor is damaged. Sea Breeze
Top LG Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
MattS1978
Level 1 Expert
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
