Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Code error 131. - Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Error Code 131 is called REPETITIVE ROTOR POSITION SENSOR ERROR..The 3 reasons this fault is appearing is 1--the wiring to the rotor sensor is faulty.--2--the rotor sensor is faulty.--3-- the motor controller is faulty.If you have or can borrow an electrical test meter I can help you test the wiring but to test the rotor sensor you need a tester called RPS tester.Please reply on how you would like to proceed an I will help you as much as I can.
Posted on Aug 08, 2010
6ya staff
SOURCE:
ERROR CODE 131 IS FOR WHAT iw712
that is a rotor position sensor or RPS fault basically the control board cant detect how fast the motor is moving, you need a special tool called a RPS tester to test it with unless you pull it out and can physically see corrosion on it, if that checks out OK the control board is faulty
Sep 09, 2014 | Fisher and Paykel Washing Machines
OKI C830 Error code 131
This is an error for the yellow LED head. Check the connection. If you feel confident enough try moving the LED heads around. If the error moves with the LED head then it needs to be replaced. If the same error occurs the the CU pcb need to be replaced.
Apr 07, 2014 | Oki Electric Industry C830DN Led Printer
How do i fix error 131 on oki printer
Please confirm the model and error code. I have checked the technical manual for the B410d and there is no reference to error 131.
Apr 07, 2014 | Oki Electric Industry B410D Laser 30PPM...
Iterra elite II printer showing fatal error 131 code error
Error Code: -131, ErrorMessage: Connection to license server failed; if license server address is invalid, correct it; if TAO NT naming service stopped, activate it and restart License Manager
I was sure that all SAP B1, and MS SQL services are up, and running on the server side so I knew this is an issue related to the client side.
The solution was checking the file "b1-local-machine" which is located it under "C:\program files\SAP\SAP Business One DI API\Conf"
The value of the server ip was "localhost", and it should be the ip of my production server instead.
Hope that was helpful.
for more hrlp visit CBR Tech Solutions
Feb 04, 2014 | Elite Office Equipment & Supplies
131 fatal error
131 code
LED Head Error
131= Yellow Head
Jan 30, 2014 | Xante Ilumina Digital Color Press Printer
Hardware Error +0137 +131 ---
This is a jam error. This error may come if the rod is jam or carrage motor is not working properly.
Oct 02, 2013 | TallyGenicom 2265+ Matrix Printer
Error code 008-111 and 008-131 out off paper but i have paper
The C118 errors you have are Registration Jam 008-111 and Fuser Jam 008-131.
You should order the Fuser Exit Sensor kit 015K60900 which is easy to install. Also, get the Registration Unit 059K45960
I hope this helps
Whit
Nov 22, 2010 | Xerox CopyCentre C118 Copier
Code 131 appears on the screen. How do I fix it?
The code 131 indicates Rotor Position Sensor Error. The Motor Controller has found an error in the pattern received from the Rotor Position Sensor. This code appears due to bad connection on the harness between the Rotor Position Sensor and the Motor Controller Module, or a faulty Rotor Position Sensor.
1) Check for corrosion on the edge connector of the Rotor Position Sensor and the Motor Controller Module connector.
2) Check the contacts on the Rotor Positional Sensor end of the Hall Harness to see if any have been damaged. (Each set of contacts in the socket has two wipers. If the distance between these wipers varies between different contacts, replace the Rotor Positional Sensor Harness).
3)Check the Rotor Position Sensor with an R.P.S. tester. Replace if it is found to be faulty.
Thank you !!
Jun 29, 2010 | Fisher and Paykel IWL12 Top Load Washer
Error code 131
Call the guy who replaced the motor/ module. Error 131 is serious. Not for home repair.
Sep 06, 2006 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
624 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
peter gittos
peter gittos
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
