SOURCE: coleman model 16 space heater
there are 2 knobs, the generator knob is the smaller of the two
there is a cap with knurles around the edge and a screw in the center, take that off and add coleman fuel.
this cap may leak air because the gaskets get old and crack- so pump it up and put some soapy water on it and see if you get bubbles
okay THIS IS IMPORTANT!!!!!!!! if you have never fired one of these up before~~~~~ dont do it in your kitchen-- you will burn your house down--- fire it up outside first to see how it works!
SOURCE: Heater won't blow hot in my coleman Seapine
did you try the limit reset button? It is red and may be close to the blower.If your pilot is on and burners don't come on this may be it
SOURCE: When I light my Coleman Catalytic Heater, it burns
The wick isnt drawing up any fuel? Does this heater have a primer?
Could the wick be sitting above the fuel inside the tank?
You might just try changing wicks and restarting.
SOURCE: I was given an old coleman camp stove
Go to http://oldtownyucca.websitetoolbox.com/ they'll tell you how.
