You say washer fills and then you say no water is entering the washer?? Burning smell is most likely motor overheating due to maybe something stuck in drain Pump.
I have read all above and these are my symptoms.
1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch.
however i tested my lid switch with a multimeter and the lid switch seems to be fine.
Under the lid there should be a small hole with a push down flap and that should be the automatic stop, which can either be a bad switch under the top of the machine or could be a broken trip/ prong on the lid that pushes this button when the lid is dropped. When the machine reaches it's spin cycle time leave it turned on and raise the lid push down on this flap with something careful to keep hands out of the washers tub and see if it works then!
Try to put it on rinse on another cycle, like normal, heavy duty or delicate. If it works, then your timer is probably bad. If it doesn't work then maybe the pump. Best of luck
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it. Good luck!
ckd cold water inlet may be full of sand ..most washers have a cold only rinse and will not advance to rinse unless fills with water..if good water flow to cold water inlet but still won't let water in suspect inlet valve
the humming noise is probably the cold valve operating but no water. check tap not turned off. slowly loosen cold water feed and check if water present
I have the same problem it gets stuck in the rinse cycle
