Question about Nextel i265
My i265 goes straight to voicemail and doeasn't allow me to answer.
    New Friend:
  • 39 Answers
Per the Sprint support site at http://search.sprint.com/inquiraapp/ui.jsp?ui_mode=answer&prior_transaction_id=2&iq_action=5&answer_id=33554455&highlight_info=6293864,0,6&turl=http%3A%2F%2Fsupport.sprint.com%2Fsupport%2Farticle%2FSet_the_number_of_rings_for_voicemail%2Fcase-ev207663-20090626-084943#__highlight&id16=voice+mail :
"A call will roll to your voicemail if unanswered after 23 seconds.
This setting can't be changed. However, on your Sprint phone, you can change your ring tone to one that reduces or increases the number of rings you hear before an incoming call rolls to voicemail.
For details about setting up and changing your ring tones, refer to the user guide for your phone."
If this is not the problem with your phone I suggest you call their support line:
Call *2 from your cellular phone or 888-211-4727 (Sprint phones) or 800-639-6111 (Nextel phones)
They may ask you to perform troubleshooting tasks, so it would be best to call from a phone other than the one you need help with.
Posted on Aug 09, 2010
Anonymous
SOURCE:
Galaxy s4 won't ring, and goes straight to voice mail.
Go onto your settings menu & change the phone answer settings to turn off voicemail, this will then allow the phone to ring as normal. I hope this helps...
Feb 21, 2018 | Galaxy Cell Phones
Phone fails to ring and goes straight to voicemail. Have checked setting !
The phone has it's own built in answer phone as well as carrier voice mail is this turned on if so turn off...
Aug 02, 2015 | Sony Xperia M2
When the Norstar m7324 phone is set to night mode after business hours, the caller goes direct to voicemail when the caller dials an extension. How do I change it so that it rings at the extension a f
Night service will only control if AA to answer (main greeting) or human, you!.
If people enter extension and it goes straight to vmail then the user invoked that option (Feature 987) which is what you should do when you leave your office.
Oct 11, 2012 | NorStar M7324 Telephone
Phone doesnt ring, it goes straight to voicemail
Hii pls chk for all saved contacts, the option "send calls directly to voicemail" is unchecked.
and also verify that the following are unchecked under: Call Settings-->Call forwarding
1-Forward when busy
2-Forward when unanswered
3-Forward when unreachable
If the problem still occurs contact your customer care executive.
Jun 07, 2012 | HTC Status
The problem is every incoming call rings once then goes straight to voicemail before i can answer
Please check if any call divert or incoming call barring (found at settings menu) are actives .
Feb 11, 2011 | Motorola Mobility RAZR V3i Cellular Phone
When I press the voicemail button to get the messages instead of going right into the voicemail messages, it just keeps ringing. The display says "Ringing ST26"
The voicemail system is not answering. Often on Toshiba systems the voicemail is a seperate PC based unit. Try locating voicemail and check for power or reboot. If this is a PC based voicemail, a common failure is the voiceboards in the PC that allow calls to be answered by the voicemail. If you detrermine that voicemail is running but just not answering, a bad voice board is the likely cause.
Jan 21, 2011 | Toshiba DKT-2020 Corded Phone
When someone calls it goes straight to voicemail and my phone is on
Check for auto-answer function and ensure it's off
Aug 14, 2010 | Lands Phones
Phone does not ring goes straight to voicemail
hello, its is possible that you have activated your call DIVERT...
Try to deactive all call DIVERT on your phone device.. Go to your settings, check CALLS SETTINGS, THEN YOU CLICK ON CANCELL ALL DIVERT..
cheers.
May 13, 2010 | Lands Phones
Samsung Tocco goes straight to voicemail when someone rings me , doesn't ring at all on my handset
Should be able to fix that in tools and settings,, call settings or auto answer settings..
have a great day !
Apr 09, 2010 | Samsung Tocco Ultra Cell Phone
Calls go straight to voicemail
You please change the setting from answer voicemail to ring mode if you have any dificaltey refer your phone user manual book and reset the option
Jun 18, 2008 | LG VX8300 Cellular Phone
Cell Phones Logo
160 people viewed this question
Top Nextel Cell Phones Experts
Ekse
SANTHOSH
William Norris
William Norris
Are you a Nextel Cell Phone Expert? Answer questions, earn points and help others
