Dryers Logo
Posted on Aug 09, 2010
Bosch logixx 6 sensitive, is not drying and when you are taking some programs,he shows F:09 and stoped
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 03, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
389
Points
Try taking of the back (middle) cap (torque screwdriver). On top of the heating element, you'll find a red (safety) button. Press till click sound.
That is all.
Pls how can i unblock a pump on bosch logixx
Turn it anticlockwise
if it won't turn it has something inside jamming it
you will need to remove the pump and filter assembly and take it apart to clear it
Bosch washer sometimes don't rinse
Have you cleaned out the filter in the bottom and made sure the pump is not blocked?
My Bosch Logixx 8 sensitive won't work and shows the code: F:43
Bosch Logix with error code F43 has "a motor fault".
You can reset the error code by the follow steps:
1. Turn the appliance knob to the off or reset position, 12 o'clock.
2. Turn the knob to the 6 o'clock position.
3. Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position. Continue holding the spin button for about 5 seconds then release the spin button and now turn the knob to off
When your turn it back on it should have cleared the error code
Check motor connector block
Check wiring
Check motor carbon brushes
Check tacho connections
Check motor
Bosch Logixx 8 shows 'UPDATE ERROR OPERATING UNIT'.
It's recommended to call Bosch Customer Support at 1-800-944-2904 and specify the exact error code when calling.
Good luck.
2helpful
Hello can you please help me.. i have a big problem with my washing machine error on F43 Bosch logixx sensitive can you send me what the problem is.. Rune from norway
For Bosch Logixx, F42, F43 and F44 all decode as 'motor fault indicated'. Sorry ;-0)
I changed the motor on our Bosch (not a Logixx) at a cost of GBP250! I do expect it to last another 20 years, though.
If this has assisted you please score accordingly.
Thanks and good luck!
John C
1helpful
F42 is showing on my Bosch Logixx 8 sensitive washing machine what does this mean and how do I fix it . thanks
An error code of "F42" means your oven has a defective or jammed lower latch, latch motor or latch switch, which is preventing the lower oven's latch from locking properly. If all of the electrical connections are in place on your oven's power board, you may have a faulty power board.
My bosch logixx 8 sensitive front load washer is sayiing pump blocked and I can't find my manual. does anyone know how to address this problem?
I have a Bosch Logixx was bought in April 2009 and I have had this problem several times, it seems like a button or coin can block the pump, you may need to try turn machine off and pull out plug, take the drainage hose out of the holder, remove sealing cap, allow detergent solution to flow out, put the closing cap back on hose, carefully unscrew the pupm cver, see if anythings stuck there, re-insert pump cover etc. I have had to call repairmen out 3 times ( pump blocked not covered under warranty) and had pump replaced, I WOULD NOT BUY BOSCH ever againa s there after care service is rubbish and I paid $1800 for this metal junk.
1helpful
Can I get a user manual for a Bosch Logixx 1400 washing machine?
Hi.
Below a user manual for Logixx 1400. There are different models corresponding to Logixx 1400, if the manual below does not apply, please ask a new question providing full model number as on service tag.
Bosch - Bosch Logixx Sensitive Automatic washing machine
19helpful
Bosch logixx code f-23 .wat does it mean?
it means the float at the base of the machine has been triggered. Open the back panel on the machine (turn off power and water tap first) then remove all screws and take metallic back off. Dry inside base with a towel and push down the float which is located in the corner. This will reset it. Keep an eye on it as it may mean you have a leak.
1helpful
Machine is locked
to open your door make sure all the water is out of your drum if not get the outlet hose and place on the floor into a bucket if water comes out than your pump is either blocked/faulty
Top Dryers Experts
john h
