Does the remote have a TV setting? In other words, is there a setting on the remote where you can go back and forth between TV, DVD, Cable, etc? If not, you cannot use it for that purpose. If it does, try setting up your remote with one of the following codes.
No special programming is required. Connect the DVD player to the TV using an HDMI cable. Note which input jack you used on the TV (example: HDMI 1 or HDMI 2, etc.) Turn on the DVD player and insert a DVD disc and play it. Turn on the TV and select the input you used to connect the DVD player (example: HDMI 1 or HDMI 2, etc.). You should now see and hear the DVD disc playing. Most settings are pre-set at the factory so everything will work without adjustment. However, both the DVD player and the TV have a Menu where you can adjust settings for picture, sound, etc. if desired.
Hi, To cancel child lock in DVP-SR200P dvd player, press power button to turn unit Off (standby mode) then press Return, Enter and Power buttons on remote. This will cancel child lock in dvd player. Hope this info will help you. Thanks.
