Usually over a period of use the washer tends to get out of balance, and then make more noise when it get to the spin cycle. I would suggest leveling the washer and then trying it out. The best way to fix this issue is by getting yourself a water level, u can get it in any hardware store. I personally would recommend a small circular water level for this job. Place the water level on top of the washer; make sure it is in the center. Take a look at the level and see where the bubble is in the water level? Accordingly you have to lower or raise either 4 corners of the washer to bring the bubble in the water level to the center. Now you have to be very gentle and small increments when rising or lower the corners of the washer, it does not take too much to move the bubble in the center.
If the problem continues then you have to open the top cover and check inside. 9 out of 10 the washer needs to be leveled.
