Speedo Aquabeat MP3 Player i Logo
Posted on Aug 10, 2010
Can't get the music to play! I charged the player and connected the headphones. When I reset the light turns off. then I plugin the player and it eventually turns green. But, as soon as I plug in the headphones and hit play it blinks orange and doesn't play anything. Please help
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Aug 14, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3603
Points
8
I do not understand the term "reset"? Have you checked that you have .mp3 files on it? Try going through the normal procedure at the pc and look at the player like an USB stick. The files should be on the top level.
3answers
Why does my kinivo bth220 headphones have a flashing red light on them no matter how long i charge them and they will not turn on
The batteries won't charge. You might want to google around for replacement batteries.
First I'd try a factory reset. PRess the +, - and multifunction button for 6 seconds until the blue light flashes and it shuts off. When you turn them on next, it's in pairing mode and try again.
My headphones wont work
Definitely the headphones are not compatible with your ZTE, if they were compatible the music would stop playing from the device at the point of plugin contact.
The headphones are OK but need to return them and get new ones that would work with it, if not, take your phone to a technician to check your ZTE headphone's port.
Nov 27, 2013 • ZTE Score
I charged my swimP3 but it won't turn on when disconnected from the computer.
The Swimp3 Player does need to be charged for at least 3 hours for the best experience. Here are some tips that could help solve your problem:
Problem: The player doesn't turn on.
Suggestion: Charge the battery in the player for at least three hours, this will allow it to fully charge. You can charge it by plugging it into the USB port on your computer or by using a USB wall charger (sold separately). If you do choose to use a computer to charge it, be sure your computer is turned on. If there is no power to the computer, then no power is going to the USB port to charge the Swimp3 player.
Additional Tip: The charging answers are in the Green Indicator Light.
If the green light is flashing off and on, then your SwiMP3 player is charging
If the light is solid green, the SwiMP3 player is fully charged
If you have no green light - then it is not receiving a charge - check the connection, make sure its plugged in properly, or check to see that there is power from the computer or USB wall charger.
Problem: I have charged my player, the light is solid green, but no music plays.
Suggestion 1: Have you loaded music onto the player? Try adding a few mp3 or wma files and test it again.
Suggestion 2: If the power is on, you loaded music, clicked the Play button and no music comes out, press and hold the RESET button for 4 seconds. It's kind of like rebooting your computer when it crashes. Many times a simple reset clears up any challenges.
If that doesn't work, then it could be the
* volume
* incompatible files or
* folders
Volume: On some units the factory volume setting is very low.
Solution: Try turning up the volume by pressing and holding the "+" PLUS button. If you click the "+" button it changes the song, pressing and holding the button will actually control the volume. And if its too loud, press and hold the "-" MINUS button to bring the volume back down.
Incompatible Music Files: If you have loaded a music file that is not compatible, it simply won't play. The SwiMP3 player works with mp3 or wma files, but not aac (like from iTunes).
Solution: Remove the incompatible files. Convert your other music files to mp3 or wma, and if you are importing your songs direct from itunes, you'll need to convert them to mp3s first.
Incompatible NON-Music Files: An MP3 player is similar to a Thumb Drive or Flash Drive because it can hold any kind of file that will fit in the drive's capacity. However, if you have loaded an incompatible file - including JPEGs, Cover Art, Word Docs, anything that is not an MP3 or WMA file, the player simply can't translate it into music.
Solution: Remove the incompatible files, leaving only your mp3 or wma files in your root directory.
Folders: The mp3 player is not able to open folders and play music files stored inside, to the Swimp3 player the folder is simply an un-playable file.
Solution: Open the folders, move or copy the music files into the root directory (remember, mp3 or wma - not aac), then delete the folders.
Michelle
Authorized Finis Dealer
Get Swimp3 Deals at WaterproofMusic.com
2helpful
2answers
Speedo aquabeat 3g mp3 player is not charging. The LED light turns to green, but when I unplug it it won't work.
You are plugging the headphones into the unit and then trying to power up the unit, correct? The Aquabeat will not power up unless the headphones are connected to the unit and disconnecting them will shut the unit off.
Ipod shuffle wont play
If iPod shuffle isn’t playing music
â iPod shuffle might not have any music on it. If you hear the message “Please use
iTunes to sync music,” connect iPod shuffle to your computer to sync music to it.
â Slide the three-way switch off and then on again.
â Make sure the earphone or headphone connector is pushed in all the way.
â Make sure the volume is adjusted properly. A volume limit might be set. See “Setting
a Volume Limit” on page 25.
â iPod shuffle might be paused. Try clicking the Center button on the earphone remote
Ipod shuffle cannot hear music through headphones
Is it really a Head phone issue? lets find out that first.
If your headphones don't work as expected or not at all, connect the headphones to another audio source, such as your computer's speaker jack or another audio device that has a 3.5 mm stereo headphone jack, and test them. If your headphones are under warranty and still don't work, you can order replacement iPod headphones - Link - https://selfsolve.apple.com/GetWarranty.do;jsessionid=1B9ED1B556F0978A6C914A52711E59AA
And about the yellow and green LEDs
The yellow LED shows when the player is charging and a blinking green LED indicates you've paused the player.
At the back is another LED, the 'Battery Status' button, just below the toggle switch; when pressed, it flashes to give you a general idea of how much battery charge remains... green indicates a full charge... yellow, a low charge... red, very low charge... and no glow means its given up its ghost.
Hope this helps :-))
2answers
S9 doesn't play music
does your laptop have a2dp bluetooth profile
this profile is needed to play music
Motorolla earphone plugin wont work on my sprint touch
im pretty sure the touch is an htc product htc and motorola are in conpatible when it comes to headphones the plugs may both be mini usb but the connections are different htc utilizes more of the connections you can buy an adapter at semsons.com to hook up regular headphones i found out the hard way and looked all over good luck
2answers
Shows the green light, but doesn't play a single song.
um i think u just need to drag songs to ur zen drive on ur c drive when u connect it to charge its better then sync the three red lights are just when u turn the volume all the way up and it will till u thats the volume limt no big deal but and if u do have music then it might be ur headphones
Top Speedo Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Speedo Audio Player and Recorder Expert? Answer questions, earn points and help others
