I had the same problem. Was able to fix it as follows:
1. Turn unit off (pull battery if on/off won't respond)
2. Plug unit into PC with USB cable
3. Hold the menu key and the joystick in the "up" position and power unit on. Make sure you H O L D all three buttons as described until unit is fully powered on.
4. This should allow the unit to go into maintenance/disk access mode. Go to the Magellan website and download the newer version of the system (ver 1.4 as of this post).
5. Follow the install directions.
After doing this, my unit came back on just fine. From what I've read, ver 1.0 of the system has some issues.
