Yeah most likely you need to replace the bulb this bulbs life span is 6000-8000 life hours about 2-3 years old use check this link out this is the lamp you need 260962
http://www.discount-merchant.com/RCA-260962-Replacement-Projection-TV-Lamp-Assembly-p/rca-260962-lamp-enc.htm?1=1&CartID=0
You probably need a new projector bulb. Google up your model and buy the best warranteed one you can find. Buy a "caged assembly" and not just a bare bulb.
Then unplug your tv and get a screwdriver. Follow your model's instructions and just snug down the electrical screws. Do not overtighten them.
Then consult your manual on how to reset the lamp timer so it knows you put a new bulb in and fires up from the first try.
Treat yourself because you've just saved yourself a trip from a repairman!!
