Get the replacement belt, and then note the pulleys that have smooth finish, and note the pulleys that have the grooved finish.
Just 'thread' the serpentine belt, one pulley after another alternating between the smooth and grooved until the last remaining pulley is the tensioner pulley.
Use the breaker bar to allow the pulley to accept the belt, and you're done.
I give you a diagrams of caravan 3.0 & 3.3 litre.
this is a 3.0 caravan serpentine belt diagram
And this is a 3.3 caravan sepertine belt diagram
greetings and good luck...;)
SOURCE: serpentine belt diagram:
The belt routing diagram is located on the top radiator cross member by the hood latch. You should see it when you open the hood. If it is not there, all Chrysler, Dodge, and Plymouth minivans, from 1993 to at least 1999, used the same 3.3L engine setup, so find someone with one and look for the diagram where I described.
SOURCE: need diagram for replacing serpentine belt on 2000 dodge caravan
I need to know which motor you have.
After you let me know, I will go to this website to find your answer:
http://www.autozone.com/N,316192/shopping/vehicleSelect4.htm
SOURCE: need serpentine belt diagram for 1994 dodge grand caravan
if you buy your belt from Autozone the belt routing is on the box
SOURCE: Need serpentine belt routing diagram for 1994 Dodge grand caravan
3.3L?
Looking at the engine from front (right side of the Van): Stating at the Top, Going Left to Right and Clockwise:
Over the Alternator
To under the Idle Pulley,
To Over the AC Compressor.
To the Left Side of the Water Pump.
To the Right side and Under the Crankshaft Pulley
To the Right side and Over and Down the Tensioner
To Under the Power Steering Pump
And Back up-to the Left side of the Alternator.
Advise when puting it on:
Put the Belt around everything else accept for the Alternator. After it is around all the rest of the Pulleys - Pull the belt up - tight from the Power steering Pump and the Idle Pulley to form a loop, holding the Belt close to the Altenator Pulley.
Using the 15mm wrench or belt tensioner bar - rotate the Tensioner Pulley towards the front of the Van and then place the belt over the Alternator.
Let me know if this helped or if you have additional information or questions. Feel free to contact me at FixYa.com!
