Posted on Sep 16, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have purchased an HP AllinOne Deskjet F2400 series printer in China on May/10. My ink cartridge (#818)is now empty and when I tried to buy a new cartridge in Cambodia (they told me a # 60 was the required one from HP) my printer keeps telling me the ink cartridge " is incompatable". What is the equivalent one to a #818 from China? I am now in Phnom Penh, Cambodia.
robert
Level 3:
  • HP Master 2,548 Answers
  • Posted on Sep 16, 2017
robert
HP Master
Level 3:
Answers
2548
Questions
0
Helped
869764
Points
8043
Refill or have someone refill ur current one.
5 Related Answers
Anonymous
  • 5 Answers
  • Posted on May 29, 2009
SOURCE: Hp deskjet D2560,incompatible cartridge
pls check your cartridge carrrier.
Anonymous
  • Posted on Jun 10, 2009
SOURCE: problem of incompatible cartridge occure in my new J 4580
i had the same problem with the hp 4580. i needed to replace the black ink which i did. then the error message appeared "incompatible print cartridge tri color"...chatted with hp customer support, wasted a hour. claimed its a hardware problem need to have it fixed. i asked would i be charge he said yes but the printer was under warranty. he asked other questions...bottom line i left the chat box....bought another hp 4580, used same cartridges, same message...THEN finally i replaced the color cartridge...and BAM! it worked on both printers. solution...replace the color cartridge...cons..if this happens again its a waste of money to keep buying the colored ink...
Anonymous
  • Posted on Sep 03, 2010
SOURCE: How to refill hp 818 inkjet cartridge
First Hole light cyan, scond hole cyan, third hole megenta, fourth hole yellow, fifth hole light megenta. now check. it will support Photo quality.
Kiran Anto
  • 420 Answers
  • Posted on Sep 15, 2010
SOURCE: HP 6310 printer ink Level doesen't indicate any ink in printer
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
BobLC
  • 239 Answers
  • Posted on Mar 02, 2011
SOURCE: I REFILLED MY HP CARTRIDGE WITH BLACK INK 818.
I suspect that your cartridge has a chip in it which is telling the printer that it is empty. You will either have to buy a new cartridge (or good compatible) or try to reset the chip
some advice on methods for resetting chips here
http://www.atlascopy.com/newsletters/Resetting_Cartridge_Ink_Levels.htm
http://www.ink-refills-ink.com/InfoPages/HP%20Resets/reset_57.htm
Testimonial: "thanks a lot ..i am trying to do the tape trick. lets see if it works out. i dont want to buy a new cartridge. "
Why does my HP Deskjet F4280 Show an E in the Start/Copy screen??
Regarding your recent inquiry about the HP 60 cartridge error message ("E in display window") and inability to print with your HP Deskjet F4280 printer, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside the cartridge itself (please note that it is very rare for both ink cartridges to electrically fail at the same time). An electronic failure of the cartridge would be unrelated to the ink cartridge refill process; these same failures can (and frequently do) occur with brand new ink cartridges.* To help identify the root cause, please run the 'Tap 41' cartridge's electrical / diagnostic tests below (refer to B. and C), this will identify which ink cartridge is causing the issue:
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
As a temporary workaround, or if you are unable to determine which cartridge is causing the issue, remove one of the ink cartridges from the printer....this might place the printer into the 'single cartridge printer mode'....print jobs may then be executed from the computer (only):
An internal electrical failure of a cartridge can be confirmed by performing the following corrective/diagnostic steps:
A.Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B.Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test:
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
      1.While holding the Power button, press Cancel (X) button 4 times, then press the 'Resume' button once.
        --- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
        ---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For any additional questions please contact us directly: [email protected]
To purchase the lowest cost ink cartridges available in the USA (remanufactured in the USA) please visit: http://www.inkplicity.com/
-Thank you
Hp 4480 how do you unpause it
The HP F4480 likely has a malfunctioning ink cartridge which is causing the printer hang (i.e. internal micro-electronics damage inside the HP 60 color or black ink cartridge). You can verify the electrical condition of both HP 60 ink cartridges by activating the Tap 41 diagnostic test report (see video here for complete instructions):
    For additional support please visit http://www.inkjet411.com
    -Thank you
2answers
2helpful
3answers
Does not print in color although we have a new color cartridge in there and the print preview shows that it should be in color
Ink may be new, but their nozzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it and the nozzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nuzzle is blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nuzzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nozzles, the procedure may be repeated over to get results.
Cartridge problem
The electronic component that recognises your cartridge is broken - it cannot be repaired. It would be cheaper, in the long-term, buying a laser printer than buying a new cartridge for your inkjet.
13helpful
2answers
i have injected 5 ml black ink in my 818 cartridge and inserted in my HP deskjetF2418 printer but it is not working and showing empty signal
4helpful
Hp cartridge 818 black refilling method and 818 tri color
why waint my hp deskjet f4280 after i have refilled the ink , it says the cartridges are not compatible
Refill of hp cartarige
it depends
all small hp cartridge use second generation ink
and you can find a multi kit
like this
http://inkfilling.net/start-pack-a-hp.html
you can use it for all small Hp cartridges
100helpful
10answers
k24674
Grand Canyon Tech
Grand Canyon Tech
