This is from your description a convergence problem, you set uses two of the STK-392-110 convergence chips.
Both chips (about 14 for a pair on EBAY) and any protect resistors (right next to the chips and easy to test) and total parts cost would be well under 30 dollars.
if you or someone you know is able (I can tell you what you will need and how to get at the parts that will need to be replaced) I will assist you---a lot cheaper to fix it than replace it.
Let me know by commenting here if you need assistance or have questions. If this has told you something you did not know rate this solution "very helpful" as I do this here for free.
REGARDS, SD TECH
HERE are photos of the parts and a typical convergence problem:
My problem is not as serious. I have a blue/yellow hump in lower left. When I use convergence alignment crosshairs I am not able to adjust blue down in #7 position. All other # areas can be adjusted Still same fix??
I have the same issue with the pink/red & greeen lines. Let me know what to do in order for you to assist in getting this fixed. Thanks
