Life Fitness 9500HR Next Generation Remanufactured Treadmill Logo
Posted on Aug 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a lifefitness 9500hr eliptical and the controls no longer light up, is there a battery somewhere if so where is it?
  • Ray Melberg
    Ray Melberg May 24, 2022
    Yes there is a battery at the base of the front column. It is a 6v 2.5Ah Lead battery. The battery I have is a Cyclon 0819-1006. This is 6v, 2.5Ah. I have replaced mine. It goes dead after a period of non-usage in my case it's a couple months.
Anonymous
Level 2:
  • Expert 218 Answers
  • Posted on Aug 12, 2010
Anonymous
Expert
Level 2:
Answers
218
Questions
0
Helped
101243
Points
358
No there is a problem with the console and it will need replaced
Eliptical 9500 HR lifefitness lights then stos
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Start by checking your battery for the proper voltage output. The following are some helpful videos.
We have Lifefitness 9500HR Treadmill. I am getting a Bad Controller Error. We have two 9500HR models. I swapped out Controller, with working 9500HR and still get Error. Keeps going into Notify Maintenance....
I would suggest swapping the consoles to see if the problem follows. If this does not help you figure it out, you are more than likely looking at a wiring issue.
Bad Controller Comm Error. I swapped out Controller but still get same error, any suggestions?
i recommend to replace the control board. This is very critical matter for the electronic machine. see the diagram attached, How the controller motor hast the 80 of control of machine.
go to www.fitnessrepairparts.com and get it
How do I change the time setting of a 9500hr eliptical for 30 min only
Dear Sir:
Read carefully your instruction manual, and proceed according.
If you do not have go for free download: www. fitness.manualsonline.com
or www.iconservice.com
sincerely. God bless you
7helpful
Where is battery located for LifeFitness' Lifecycle 9500HR
The Lifefitness Lifesyscle 9500HR battery location is at in the lower portion of the recumbent bike. This is a 1/2 to one hour task for most do it yourself'er.
In order to gain access to the battery compartment,you has to remove the pedals.
The center cover has to be remove.
Additional reference: Lifecycle Battery 0819-0012 Model Description Terminal Volts AH L W H Lbs Price 0819-0012 Fits Lifecycle Stairmaster series 4200, 4400 - Lifecycle Lifefitness CT8500, CT9100, 9500HR, 95Ci - Star Trac 5300/6300, 5400/6400, StarTrac 6100 Pro, 6200 Elite, ET4600 (0819-0012 replaces the 0819-1006) F2 6 2.5 4.48 1.81 2.75 2 $19.80
1helpful
Lifefitness 9500hr recumbant exercise bike dead
This unit takes a special 6 volt battery. The battery is in one of two places. First place to look is under the unit. If you lay the bike over on its side there is an opening in the covers. If the battery is not there then you will need to take one of the side covers off. When you get the side off you cannot miss it. The battery is black with three cylinders. You can get the battery from sportsmith.net.
5helpful
Manual for lifefitness 9500hr treadmill old modle
Just call Life Fitness and they will send you one via e-mail attachment.
(800) 351-3737 between 8 a.m. and 5 p.m., CT Monday through Friday.
stephen
Top Life Fitness Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
