SOURCE: FS-3900DN Error 0150:0000000
This is a common error but I have done heaps and fix has always been use clean formatted stick, get lastest engine firmware
copy to root of usb stick or CFlash card(side), power on printer with stick in socket I double check your copy engine firmware
I use engine S2F9_1000008002.x and system, S2F9_3000008002.bcmp . allow to complete, remove stick, youre done, if this fails and I've done probally 100 and yet to see a fail then try with CF card if that also fails then you will need new eprom from kyo
SOURCE: copy count
You should be able to get the meter reading on a 7022 by pressing the star key (*) on the numeric keypad.
Hope this Helps
SOURCE: Kyocera 3900DN Error Code
F030 General failure
Miscellaneous failure with the main
PWB, other than F000, F010, F020,
F040 and F226, above.
Defective main-PWB
Turn the power switch off/on to restart the
printer.If the error is not resolved, replace
main PWB
SOURCE: error code 7410
Open the left side door, push in on the drum unit which is above the waste toner bottle until it clicks.
Turn printer off then on.
