Ck the bottom of freezer and if ice is there . the drain is pluged and water is running out the door on floor . every 8 hr of compressor run time the unit will defrost and water on froor .
Where is the drain and how do you access it to unplug it?
The drain is in the freezer located in the back under the cold coil . . every 8 hr of run time the defrost cycle clears thecoil of ice build up / this water drips into a drain pan and drains through a tube that goes to the pan under neath. at that point the air the cools the compressor dryes out the pan . . if the water does not go through this tube it ends up on the floor of freezer and out the door on the floor . some models you can not see the drain unless you remove the back of the freezer . your's will be like this . / to clean drain I use hot water and a turkey baster . .. hope this helps you . mm
