Panasonic Lumix DMC-FZ7 Digital Camera Logo
Anonymous Posted on Apr 29, 2008
No zooming Hello The lens do not response when I am turning the zoom ring?!
  • 4 more comments
  • Anonymous Apr 29, 2008
    Hello
    The lens on my FZ7 do not response when I turn the zoomring?!
  • dannymartus Aug 29, 2008
    the zoom control not responding
  • franp Sep 23, 2008
    zoom control button sticking; control sticks causing zooming in/out to continue to max
  • RNihan Nov 04, 2008
    I have the same problem the zoom knob doesn't work.
  • Anonymous Dec 30, 2008
    The zoom toggle switch doesn't do anything. I have a Lumix MDC-FZ8.
    Thank you
  • RNihan May 11, 2010
    you clarified that it is a zoom control not a zoom ring but you didn't give a solution
alexander sakelliou
Level 2:
  • Expert 95 Answers
  • Posted on Jun 02, 2008
alexander sakelliou
Expert
Level 2:
Answers
95
Questions
0
Helped
26689
Points
111
Sorry but the dmc-fz7 does not have a zoom ring only a zoom control on the top right.
Zoom on nikon d5100
In either mode, you're zooming by turning the zoom ring on the lens? In live view mode, if you zoom in by pressing the magnifying glass button, all you're doing is zooming the display, not the image itself.
1helpful
Hello please help in live view mode when i press the button to zoom 0x/5x/10/ the pic is very close in my LCD screen.my question is that when i am at 5x or 10x when i want to see my pics i have taken in...
The zoom button merely zooms in on the display. It magnifies a portion of the picture so you can get a better look at what you're about to photograph. LiveView or otherwise, if you want to zoom, you have use the zoom ring on your lens (assuming you're using a zoom lens in the first place, of course).
ROKINON AUTO ZOOM Macro--- HELP to enable macro
Some of the Rokinon (and other ) zoom lenses could only go into MACRO at certain focal lengths- the lens you have "zooms" from 80 to 200 focal length,but is that done by "sliding" a ring forward and back on the lens, or by twisting a different ring that the one that focuses?
1helpful
Hi I bought a pro-spec 70-210 lens for my Sony Alpha. When you go to zoom out it doesn't twist. You can pull it straight out...Is this how it should work? The rest of my lenses all twist out
Yes. It's a push pull zoom action.
One touch zooms as used on 35mm film SLRs used to have the same mechanism, the zoom ring twisted as well to achieve focus but now that most lenses are autofocus that's unnecessary. So you have a lens which just retains the push-pull, a far more natural action in my opinion and usually faster than a rotating zoom. Once you get used to it I think that you'll prefer it.
By contrast, most modern zooms have what was considered in 35mm terms to be an old-fashioned twin touch zoom: one ring was turned to zoom the lens and another was turned to focus it. This sometimes meant that after zooming you had to refocus; your push pull zoom will likely have a more technically demanding constant focus zoom action, there will be an additional manual focus control as well, but it's very much a minor secondary control used only when your AF has broken or is switched off.
I hope that my reply has been of use to you, please return the favour by rating my answer.
How to achieve full zoom with a Nikon 55-200mmf/4-5.6G ED lens?!
1) What camera body are you using?
2) I do not understand your assertion that it automatically zoomed in. Zooming is a manual function. The automatic functions of your lens pertain only to focusing on of the subject so that your picture is sharp and ensuring that the correct amount of light is admitted so that you have a correct exposure.
3) Are you sure you were turning the zoom ring and not the f-stop ring? The zoom ring is labeled 200 on one end of the scale and 55 on the other. It is also the widest ring on the lens barrel. When you rotate it, the physical length of the lens will lengthen as you rotate it clockwise (viewed from behind the camera) and shorten as you rotate it counter-clockwise.
4) For reference, at 200mm the angle of view on your lens should be 10 degrees and at 55mm about 40 degrees.
2helpful
Zoom ring is loose and drops/slides on its own
Yes, this happens even when the lens is brand new. Some other lenses have a Zoom lock to prevent it. What I did was to slip a flat rubber band around the black area just behind the zoom ring, the area where there is s white mark or line, with the band ring just touching the zoom ring. The rubber band should be fairly tight, but not too tight. When the zoom ring revolves, the rubber band touching it gives it just enough friction to prevent it from turning. You can adjust it to give as much friction as you want. Hope this helps. Jay
1helpful
My question is about a Quantaray 75mm-300mm
Slide a piece of paper partway under the ring (make sure you leave enough hanging out so you can remove it later) and see if that tightens the action some.
Another low-tech approach is to push the ring to expose the inner barrel, then attack one or more pieces of Scotch tape or masking tape.
2answers
Zoom ring on 18-55 mm lens is locked/stuck
Are you sure it's the zoom ring that's stuck, and not the focus ring? The focus ring doesn't move when the camera is in autofocus.
If it's indeed the zoom ring that's stuck, you can spend more money than the lens is worth in repairs, or buy a replacement (circa 35 dollars on ebay) for dreadfully cheap. Good luck.
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
