Life Fitness 9100 Next Generation Remanufactured Treadmill Logo
Miguel Garcia Posted on Aug 13, 2010
I can't reset a fault named "wax empty" and my equipment doesn't work life fitness 9100
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Aug 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
2952
Points
5
Hit the stop button and hold down pouse key until the counsel repowers up and tougle throug to mantinace enter then tagel throug to waxer refill and hit enter
1helpful
How do i refill the wax on my life fitness 9100 treadmill?
open cover on left at rear of treadmill, disconnect pipe, fill with wax kit and then reconnect pipe, 2 screws to remove wax cover.
Treadmiill keeps saying waxer needs filled after filling it
please see the cause and remedy and fix it. Please read carefully your section of troubleshooting instr. manual or download
Inspect spray pattern between 8" (200mm) and
16" (400mm).
If not, verify wax nozzle is clean, hoses are not
kinked, wax bag is not empty, or wax is
contaminated.
http://www.sportsmith.net/images/product_support/lifefitness/Treadmills/TR9100/9100 Treadmill Manuals/Service/m05100k
God bless you
I have A Life fitness 9100 treadmill The display shows the message "maintenance notes wax over" how can I remove this error?the treadmill will not turn on HELPPP
see this steps and fix it. .Of course you must read your instr. manual or download from www. iconservice.com
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
  • 2 Press the "ENTER" button three times to access the treadmill's error log.
  • 3 Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
  • 4 To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
  • 5 To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
  • 0helpful
    What's your problem?I have a life fitness 9100 hr I have a problem how do I clear the message waxer tank empty?
    see this step and fix it. God bless you
    Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
  • 2 Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • 3 Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
  • 4 Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.
  • 0helpful
    Describe your 9100 Next Generation Remanufactured Treadmill Problem display shows waxer disconected ???
    Dear Sir:
    I will help you inmediately.
    1) Display does not illuminate
    when machine is powered
    on.
    Insufficient power source.
    Plug treadmill into a dedicated amp circuit.
    2) Loose 10 pin connection at
    display console or wax/lift
    control board.
    Check all electrical connections for proper
    attachment.
    3)Damaged main harness wire
    connection.
    4)Replace wire harness.
    Faulty display console or Wax/
    Lift Board.
    Verify if 8VDC is present at P1 pin, 3-4 and
    12VDC at P1 pin 9.
    a)If yes, replace Display Console.
    b) If no, replace Wax/Lift Board. See How To...
    Replace Wax/Lift PCB.
    Use VOM digital (Voltimeter)
    Hoping that you can resolve, if you need some extra help, please reach me.
    blessing.
    E.CUADRA
    MANAGUA, NICARAGUA. C.A.
    I have a life Fitness 9100 that do great walking but if I start running on it, it will automatically shut down to start menu. Is it the wax? or any suggestions?
    the stop switch is bad to check this out start the tread and press around the stop switch on the counsel and see if it shouts down
    2helpful
    How do i reset the waxer on a 9100 lifefitness treadmill?
    Press these buttons:
    101–ENTER–
    HILL–RANDOM–
    FIT TEST.
    Program lights come on. Display will scroll toWAX DELAY OFF.
    Press speed "UP" or "DOWN"
    to toggle to
    WAX DELAY ON or OFF.
    2helpful
    I have a life fitness treadmill and put new wax in the blader how do i start the machine and put wax on the belt?
    you will need to go into service menu by pressing and holding the pause button then pressing the clear button twice , continue holding the pause until the service menu appears. then use the arrow up and select maintenance press enter then either use arrow up or down scroll and say refill waxer system or replacing wax bag press enter, this will reset upper console. Upon completion of this the go back into the diagnostic menu select system test press enter scroll up or down to waxer manual mode hit quick start and that will fire up the wax pump and your done
    1helpful
    Refilled with wax how to reset display
    you have to enter maintenance mode, press (CLEAR) and then press the key (PAUSE) there will appear a message that is doing a checkup, then using the keys you move up to find "Maintenance" and press enter Ahi provided with keys look for the option "WAX REFILL" press "ENTER" and ready and be 100% if you have any additional questions here's my e [email protected]
    Treadmill says "workout paused" about every 10 sec. when in use. How do I fix it?
    you must first check if the system is working wax, second this warming probably DECK. in this case you should replace it. You should also know if you have the connection with a dedicated electric circuit 20Amp and finally the last thing you should check is the "Emerson Controller"
    Top Life Fitness Exercise & Fitness Experts
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Mike Cairns
    Mike Cairns
    Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
