Hello cjsmith12345 - Are you certain the error code is C8? However, if you are receiving an error code E08 it typically indicates a shorted keypad, or a faulty User Interface Board. Depending on the model, these components may be the same. To reset, turn the power off to the unit for two minutes. This may be done by either unplugging it or flipping the household circuit breaker off and then restart unit. If error reoccurs, I would strongly recommend contacting a professional to make the necessary repairs. Unfortunately, most electronic parts cannot be returned so it is always a good idea to get the appropriate diagnosis prior to making any unnecessary part replacements.
Hello - Typically 88:88 on an Electrolux dryer indicates a generic power failure code. Try resetting the unit by unplugging it or flipping the household breaker off. Wait approximately ten minutes.
Hi - Typically error code E08 on Electrolux models indicates that it is recommended for a professional to check the mist value on the motor. Try resetting the unit by unplugging it or flipping the breaker to the household circuit breaker. Wait approximately ten minutes and turn on the dryer. If the error code does not clear and it is ineffective, contact a professional to move forward accurately.
hoover dryer error code : E08
