How to Reboot an eMachines PC
If you are able to load windows:-
Note:Before performing system recovery try to back up the important data like pictures and files.
Instructions
Step 1
Click the "Start" button on the Windows desktop. Check through the program list and hit the "Recovery Management" option
or
Click the "Start" button on the Windows desktop>>go to All programs>>Emachines>>Emachines Empowering technology>>Click on "Recovery Management/ & follow the onscreen instructions Click on Restore>>select factory default settings>>click on yes to follow the warning instructions
It will take 10 to 15 minutes to compleate the process
If you are unable to load windows
1)Turn off the computer/unplug all the external devices like Printers/Scanners/USB devices/Webcams etc...
The moment when you turn on the computer try to hit F11 on the keyboard>>it will give you the options just follow the onscreen instructions.
If F11 doesn't work try with Alt+F10
SOURCE: reboot to factory settings without disc
Can you still log in to Windows Vista?
e machine has a RECOVERY MANAGEMENT allows you to restore sytem to factory default or reboot and tap F10 and follow instructions.
Good Luck!
SOURCE: How do I factory restore an Emachine w3609?
You might be able to purchase a set of factory image CDs from eMachines, but not all manufacturers make them available. You might also find sets for sale on eBay and from some other vendors.
Without the factory restore CDs, you can still reinstall Windows but you'll need to do a little more work. Download the drivers for your system (audio, video, etc.) from the eMachines website and save them on a flash drive. Find a copy of the XP installation CD for your version. You may be able to borrow one from someone. Do a regular installation of Windows, using the product key from the sticker on your computer. Install the drivers you downloaded as required for anything that Windows doesn't properly detect and support. Then activate your Windows installation.
This is sometimes a good thing to do. Some brands of computers come preloaded with so many "bloatware" applications and programs that try to be helpful that doing a clean install like this gives you a faster system when you're done.
The downside is that any preloaded applications that may be worth having, such as antivirus/antispyware applications, media players or CD/DVD burning software won't be there. You will need to do that yourself. There are plenty to choose from for downloading. My picks are avast! for antivirus use, InfraRecorder for disc burning, Winamp for media playing.
SOURCE: I wana restore my computer to its factory settings its emachine with xp on it
1) Go to start menu
(2) Click on all programs
(3) click on Emachine
(4) click on Emachine recovery management
(5) Click on restore on the bar across the top
(6) click on restore to system factory default
If your particular eMachines model didn't come with recovery media or you just misplaced the disc, you don't want to be caught without a means to restore the operating system.
It's all too easy to accidentally download a virus or experience any number of problems that make your computer unstable.
However, there is an option for restoring your computer without the original recovery disc by using the pre-installed recovery software.
Use an external memory device such as a DVD, flash drive or external hard drive to back up the data you need to save from your eMachines computer.
Any data that isn't saved to an external source will be erased when the computer is restored to factory settings.
Remove any discs that are in the optical drive and unplug the computer's peripheral devices, such as an Ethernet cable or scanner.
Do not disconnect the keyboard, mouse or monitor.
Click the Windows "Start" menu and choose "All Programs."
Navigate to "eMachines" and choose "eMachines Recovery Management." Click the "Restore" tab.
Click "Password Settings" if you have not already set a recovery password. Type a new password in the text box and click "OK." Click "Restore System to Factory Default."
Type the recovery password and click "OK." Click "Next" to wipe the eMachines computer's hard drive and begin the recovery process.
Select "Finish" and wait for the eMachines computer to restart.
Use the series of installation prompts that appear on the screen to create a new user account for your operating system, set the system date and time, and set up your internet settings.
hope this helps
