LG 42LE5500 42 in. TV Logo
Posted on Aug 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, how to enable subtitles for DivX movies from USB on LG 42LE5500? I connect USB, TV recognizes folder where DivX .avi file is but within same folder it does not "see" .srt subtitle. Also, in settings for "video player" only "picture size" can be modified - audio language as well as subtitle language positions are grey. Any hints? Thanks
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Aug 22, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
23827
Points
16
It seems that subtitle file must have exactly same name as movie file. For example: Movie file: Mission impossible.avi Subtitle file: Mission impossible.srt or Mission impossible.sub or Movie file: Mission_impossible.avi Subtitle file: Mission_impossible.srt
  • 1 more comment
  • Anonymous Apr 24, 2013
    Yes, but how do i put two files with same name in one folder
  • Anonymous Apr 25, 2013
    Yes, you can place two files with the same name in one folder, because their extensions are different.
  • gume_ Jan 22, 2014
    Is there any way to add multiple subtitles?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 01, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
23334
Points
I have LG 32CS460-ZA LCD TV, when I play any movie from the USB port I faced a problem with the subtitles... it does not "see" subtitle.... can you help me????
Anonymous
Level 1:
New Friend:
  • Posted on Dec 09, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
23334
Points
Be sure that the file name doesn't include ".srt". The pc is able to recognize it as an extension of the name, while the LG-tv is not. And avi and srt files must have exactly the same name in order to work together.
  • Anonymous Sep 12, 2012
    Wow this actually worked for me, only sometimes it actually works while not removing the .srt extension.. Some really weird firmware, they might consider upgrading. Anyways, thanks alot!
    This really did the trick for me, weird as some .srt files did work and some didn't. Anyways thanks alot dude!
Anonymous
Level 1:
New Friend:
  • Posted on Mar 21, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
23334
Points
Set encoding type of the srt to ansi instead of utf8,
by opening the srt with notepad, save as (name..) and choose ansi before saving
Vinho Xie
Level 3:
Genius:
  • LG Master 1,419 Answers
  • Posted on Jan 26, 2022
Vinho Xie
LG Master
Level 3:
Genius:
Answers
1419
Questions
0
Helped
414100
Points
4431
You can combine your video with subtitle. Then you can play it freely on TV with USB. The VLC media player is one excellent tool for smart video consumers and even a lot of professionals. This program is very stable and simple to handle. You can use it to play almost any format video smoothly. It is without any configuration hassle. It can run very well, which allows users to do many tasks related to videos like subtitling videos. Check out this article and you will learn the way to use VLC to add subtitle to video file easily.
Marko Gugic
Level 1:
New Friend:
  • Posted on Jul 31, 2015
Marko Gugic
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
23334
Points
Thank you for all the help, guys. I had also no subtitle when I was watching movies using USB. Now after I renamed my subtitle file same as the AVI file is and I put two subtitle files, one with .srt and one without extension, it works great.
My TV support .srt, .sub and many other subtitle extension. So, I think the same name matter. Will test this next time.
Thanks!!
3 Related Answers
Anonymous
  • 131 Answers
  • Posted on Aug 09, 2011
SOURCE: how do I turn the subtitles off in my lg tv?
Look for the CC button on the remote, press on it until the subtitles (closed captions) are off.
Anonymous
  • 211 Answers
  • Posted on Jan 29, 2009
SOURCE: can not delete subtitles on my LG Plasma TV
If you've got a cable receiver, you can change that in the menu of that receiver.
Or maybe the setting on textpage 888.
Cheers,
Gerard
Anonymous
  • 4889 Answers
  • Posted on Mar 01, 2009
SOURCE: How do I switch off subtitles on my LG 19LG30 19 in. HDTV LCD TV?
Hit the menu button, select options , select "hard of hearing", turn off and press ok.
I have LG TV 42LD550. When I try to play a movie from Flash drive using YSB it get the message "There is a problem with USB. I have used the format MacOS Extended (Journaled) as well as FAT.
To use a USB flash drive with the LG 42LD550, the drive must be formatted as a FAT32 or NTFS device. The drive should be 32GB or less. Not all USB devices will be recognized - this can be a driver issue. (I've had a few devices that didn't take a USB flash drive, if the drive required a driver to run under Windows 98.) If you use an external drive (portable or desktop), keep the drive capacity to 1 TB or less.
Next what files are on the drive? This TV will only recognize JPG images, HD DivX (.avi and .divx) movies and MP3 audio files. The not all codecs may be supported with these formats. Some people report losing the ability to play movies after certain firmware updates. If the drive has too many folders or files in a folder, it may not work. (This will happen sooner with the FAT32 format.) See page 96 of the user manual to see the file format limits on the USB port. The manual is available on the TV support page: https://www.lg.com/us/support-product/lg-42LD550 . The current link to the manual is http://gscs-b2c.lge.com/downloadFile?fileId=oqXZ71Wn8YXJ3OKzy9leAw .
I hope this helps.
2answers
Panasonic DVD S48 - DVD player how to play movies over usb
Yes, I know Panasonic DVD S48, if your movie file is right divx avi movie file, you can directly transfer the divx avi movie file to your usb disk and play on your Panasonic DVD S48, but if your movie files isn\'t divx avi movie file, you have to use a right software to convert your movies to right divx avi movies, then transfer to your usb disk, convert any movies to divx avi movies.
1helpful
3answers
Hi i have LG 42pg20 plasma tv , it have divx built in but it cannot able to play mkv file format , but avi or mpeg play , how can i upgrade divx software in tv to divx plus . divx plus can play mkv...
you can't and DIVX is an AVI format. MKV is an entirely different encoding format. There are no TVs or DVD players that support MKV. Also you will not get a DVD player that will paly BlueRay. DVD and BluRay require 2 different lasers on the drive to read the format so your software will not allow for this through a USB or hdmi either. You have what you have and there is nothing you can do aside from using the PC the movies were pirated from and connect it to the TV.
1helpful
I HAVE A KDL 40 EX 600 and whant know how to put subtitls on movies from usb?
When you download the movie it should have two parts folder in your sticks....
.avi ( picture folder)
and one of these as :
.srt / .txt / .sub folder (subtitles files )
and both of the folders should have the same name ( of the movie )
So,unless you have these 2 folders together , you are not able to see ant subtitles..
if it is ok,than sub comes automatically when you start the movie..
Hope this helps! Take care and please Remember to rate/vote
and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
1helpful
Hi, I have a LED TV Sony KDL 40EX600, and I can't insert subtitles when I want to watch a movie from USB stick. Do you have the solution for this problem?
(subtitles files )
So,unless you have these 2 folders, you are not able to see ant subtitles..
Thanks
4helpful
My Sony Bravia KDL40HX800 led tv plays divx videos but cannot read external subtitles, they dont even appear when I open my usb connected on the tv. Please tell me which steps should I follow so as to...
If you already name the subtitle file (.srt) with the same name of movie file (avi, mpeg, mkv etc) all you have to do is press green button on the remote control the turn on/off the subtitle. It works for me.
1helpful
3answers
I have a serious problem...i wont to see movies with greek subtitles and every time i put the srt file in my movie file (avi,divx etc...) it seems that its added but when the characters starts speaking,the...
Firstly i am not able to understand your problem correctly.What i think your problem i am writing solution according to that.
Try playing in different player or better player like vlc which can play all types of media files.
May be there is some problem in your player caching.As caching needed everytime u play a movie.Try uninstalling your player then reinstalling.
Hoping this will work
1helpful
2answers
Can't play divx or avi
Thats because Divx or AVI is not a recognized format for a DVD Player. If you are burning a disc you need a software that can create a DVD Format Disc from an AVI as all DivX are AVIs. I reccomend Ulead DVD Workshop 2:
http://www.corel.com/servlet/Satellite?pagename=us-Ulead/UleadProcessLayout&lc=en&ppg=CorelCorp/Trials/Login&pid=1177441179026&cid=1204918457206
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
