My cspro copies prints but there is a intermitant horizonal line about a quarter down the paper and the copyis kind of dark because it is too much toner on the paper copy.
Put paper in the manual feed tray(tray 1).
Print something.
When the paper gets about 1/2 way into the printer, open the top cover.
Pull out the toner. Look down at the paper in the printer.
Do you see a thick dark line? Replace the toner.
No thick dark line, check the fuser for damage.
hi, HP Officejet 5610 All-In-One InkJet Printerhas few common problems. Such asDriver CD lost,Scanner does not work,Connection problemetc. For find all these software solution just clickhere....
It depends... never use a Reman cart in these machines... only use sharp...especially if the machine is under warranty. Does this happen when, Using the Doc Feeder When making copies from the Glass Or when you print from a computer (assuming you print from a PC) If you print something and this happens then it is inside the machine Probably toner or developer dumping... Take a few pieces of large white paper and cover the entire glass surface... make a copy is the line there? If so see the answer above... if not then close the top and make a copy with no paper on the glass... is that black line there.. If so then your top needs adjustment... One more test If you make a copy using the doc feeder, this black line only occurs when making copies with the doc feed, clean the **** glass, and try again...
Dark copies (whole pages) are usually a result of poor charge of the drum. Drum is that green thing (usually, seen blue ones too). You get text and graphics in places, where the drum has been discharged (light discharges drum). So if everything is dark - the drum is discharged fully, or not charged at all. Look for bent, dirty or missing connector plates, springs, paper covering contacts. If you get lines it could also be the fuser (hot thing) - needs replacing. Everything depends on how the copy looks like, I would have to see it. Hope this is helpful somehow ;-)
