GE WSXH208A Front Load Washer Logo
Posted on Aug 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No matter what wash temp I choose clothes appear to have been washed in hot water. Colors are fading eltremely bad. I normally wash everything in cold except whites.
Anonymous
Level 2:
New Friend:
  • Expert 70 Answers
  • Posted on Aug 15, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
70
Questions
0
Helped
26348
Points
172
Try turning off the hot water valve unless you need it. Its either behind or next to the washer...usually a red knob.
2answers
Rinse cycle water temp
You may have a leaking hot water electrovalve, replace it.
How do i prevent colour bleed from fabrics?
You can't. Best option is not to mix colors with white when doing hot wash. Generally colors on own go well with cold wash with the right detergent. When you get new colored clothes like pyjamas rinse separately overnight to get non fast colors out and then put in the general laundry. But always keep whites on separate wash.
1helpful
Sheets how to wash do not fade?
I believe it's Tide, I could be wrong, but one of the major brands has
a detergent that helps to keep colors from fading. Also, don't wash them in hot water. The new detergents work just as well in cold
water as they do in hot. If you can line dry them, during the day when they can get a breeze, without being in the sun, that might
help keep your colors from bleaching out. If the sheets are from
your sons bed, you might think about getting some of those pads
like the hospital uses. You know the blue ones that they always
put under you on the bed. They make some that are pretty big.
I would check at a Walgreens or CVS. They should carry them.
I have a top loader Speed Queen and I had it just serviced. I use Bio Classic Soap and Softner. I wash my dark clothes inside out but the white spots still appear on my dark clothes. Ihave diluted the...
Vinegar is good for cleaning scale off of appliances. I would us more then 10 ml. It won't hurt anything. Have you always used the Bio Classic Soap without any problem. You may want to try another kind or dissolve it in hot water before adding the clothes and switching to the water temp you normally use. Do neighbors also have this problem with the lime water.
After wash cycle still has water leaving bad smell on clothes
Most maytags don't heat water so even if you select hot wash it will only wash at the hot water temp available in your home, so you could end up with a cold wash
What do the fabric settings mean?what is the difference between colors and brights?
some fabrics shouldent get so hot theyll fade,some its fine theyll dry at hot. colors are colored clothing ,brights are basically whites .
1helpful
Green whites?
This often is called "lint" but is really a "whiting" left by un-dissolved soap and can be seen at it's worst on dark colored clothes. This is made worse in a colder climate where the cold water entering the washer is much colder than normal. Things that can effect the quality of the finished washed products.
Too much soap: ( we have a test for this further down the page ) If you follow the manufactures instructions on the box, then chances are you ARE using too much soap. They like to sell you their product, I find cutting usage in 1/2 of what the box says will still wash good and also cut your chances of getting "whiting" on your clothes.
Over loading the washer: Even if the agitator is suppose to go back and forth, the clothes are not. If you can hold the lid button on your washer so you can watch the clothes wash, they should 'roll" in the basket and not go back and forth like the agitator. The clothes will go down the side of the agitator, across the bottom of the basket, up the side of the basket and across the top of the water in a rolling motion. Overloading is not just too many clothes but also too little water for the size of the load is another way of having a overloaded wash load.
Water temp is important: Use a thermometer to test the temp of the incoming water in your washer. Hot water should be close to 140 degrees F. Warm water fill should be 100 degrees F. Cold water is approx 60-80 degrees F. What happens in a cold climate location is the cold water temp drops as the outside temps drops, once the water temp gets below 60 degrees F, it can no longer dissolve the soap properly and will most definitely leave "whiting" on the clothes!! Do not use a cold wash, wash your clothes in as warm as poss.  water as they can take. If you have delicates you want to wash in cold, start washer out with warm water as you are putting in the soap and fabric softener and clothes, then switch to cold to let it finish filling up, this will give you a warmer wash but not as cold as straight cold water. I find most washes can be done in a warm wash / cold rinse just fine. If you need ( and probably will ) to adjust your warm water fill, turn on the hot water tap fully, turn off the cold water tap. Let the water start to fill on a warm wash setting. Then slowly turn on the cold tap adding the cold water to the hot water making a warm fill....use a thermometer to set water temp and leave the taps stay when you get about 100 degree F water fill. I adjust my own washer usually twice a year, one on summer time and once in the dead of winter.
Test for too much soap or soap retention: Put in a load of towels or dark clothing that has been bad for the "whiting" problem. These items are bad for holding soap and getting what is called -soap retention-
Wash the load in the warmest poss. water, DO NOT add any soap. Let the washer fill with water and wash for approx. 5 minutes, lift the lid and observe what is on the top of the water. If you see soap and bubbles on top of the water, your clothes have soap retention, this soap came out of your clothes. Let the load finish with out adding any soap and wash all clothes effected with this "whiting" residue. Once all the soap is washed out of the fabric and you start to add some to each load, use about 1/2 of what the box says. Liquid soap has less problems with "whiting" than the powder does, but I find powder soap is better at getting my own personal clothes cleaner.
2answers
Is fading and shrinking my clothes
low temperature and low rpm of motor,must try this.
Small brown spots on whites
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
