Question about Fuji FinePix A800 Digital Camera
Display reads "images recorded in internal memory" but there are none and I can't take more than 4 pictures until the camera says the memory is full. Also the memory card says it is full after 7 pictures, this is a 16mb card
  • 4,102 Answers
Hi, the memory card you are using is to small for the camera it has not got enough memory on it you need to get at least a 1gb memory card or 2gb memory this will then allow you to take between 500 and 1000 pictures the 16mb card you have in is not worth using it will only hold a couple of pictures so go to the well known auction site and buy a 2gb memory card of the same type such as sd card or micro sd or mini sd it should tell you on the 16mb card what type it is then just buy the same type but with either 1gb or 2gb or even 4gb of memory this will then let you take 1000s of pictures
the 16mb card is no good in your camera get a bigger card and your problem will be solved
let me know if you have any problems with the new card ok
Posted on Aug 15, 2010
Testimonial: "Spot on ta! very much!!!"
6ya staff
SOURCE:
I have a panasonic Lumix HD AVCHD lite. Other numbers/title: DMC-ZS7 I thought I had a full memory card when the screen message read "Images will be recorded to internal memory". It...
Your card is probably good. Go into the camera's setup menu and find the picture storage or memory section. Select external memory as default and you should be good to go.
May 14, 2011 | Panasonic Lumix DMC-FZ18K Digital Camera
I put my memory card in my computer to upload photos; and it says there are none, but, the camera is saying its full
Does the camera say it's full even with the card out of the camera? If so, the camera is telling you the internal memory is full, not your memory card. The camera will not write to the card until you format the internal memory while the card is out of the camera.
Dec 14, 2010 | Kodak EasyShare C330 Digital Camera
How to save a picture to a memory stick,,
Even if the Memory Stick Duo is inserted in the Camera, the images will not be saved in the Memory Stick Duo until the capacity of the Internal Memory is full. To save the images in the Internal Memory to the Memory Stick Duo, select the EXPORT option from the Viewing Menu of the Camera. Touch the MENU icon when viewing images to select the IMPORT option.
There are two option in the Viewing Menu of the Camera (Export and Import). Export option is to save from Internal Memory to Memory Stick and Import is for saving from Memory Stick to the Internal Memory.
This Camera is having 4GB of Internal Memory, hence the images captured will get saved in the Internal Memory first and then to Memory Stick once the Internal Memory is full.
Thanks for using FixYa
Dec 04, 2010 | Sony Cyber-shot DSC-T2 Digital Camera
How do I record photos using memory card? I can't figure out how to switch from the internal memory to the memory card. Read the book...asked my daughter...asked my husband and none of us can figure it...
Most digital camera's automatically recognise when a memory card has been inserted and automatically writes to it. When full, it looks for capacity on its internal memory. All you have to do is make sure both are empty when you download your pictures.
The more sofiistcated, SLR type camera's do sometimes have a card/memory switch option built into their firmware.
Mar 14, 2010 | Olympus FE-360 Digital Camera
Memory card
Use the camera not a computer to reformat the "card" or internal memory.
Make sure the setting in the camera is set to record on the card or internal memory. Whichever you are using.
Dec 22, 2009 | Canon Powershot A2000 IS Digital Camera
Using Internal Memory...now says memory full, no image!
I own the same camera, Not sure about no pictures showing in the memory but you can get a 2 gig memory card for around $20 in stores or around $15 or $16 on ebay, holds over 700 pictures at the highest resolution. Also try to download your pictures to your computer if you haven't already. Hope this helps.
Sep 28, 2008 | Samsung Digimax A503 Digital Camera
Can't take photo's
There should be 2 settings, 1 for internal memory, 1 for external (card) memory. Internal memory is always low, especially if camera is set to high quality photos so only a few can be taken. check your settings on picture quality.
Jan 04, 2008 | Fuji FinePix S8000fd Digital Camera
Fe170
You can add memory to your camera by purchasing an xd memory card.
Compatible cards
xD-Picture Card (16MB – 1GB)
There are two ways to record the pictures you take with this camera.
Recording pictures to the internal memory
• Pictures are recorded to the internal memory, and when the number of storable still
pictures reaches 0, you must connect the camera to a computer to download the
pictures, and then erase the pictures from the internal memory.
Using an xD-Picture Card (optional)
• Pictures are recorded to the card when inserted in the camera. When the card is
full, you download the pictures to a computer, and then either erase the pictures
from the card or use a new card.
• Pictures are not recorded to the internal memory when a card is inserted in the
camera. Pictures in the internal memory can be copied to the card using the
[BACKUP] function.
g“BACKUP Copying pictures in the internal memory to the card” (P.25)
“The card” (P.60)
Number of storable still pictures and recording length of movies
Still pictures
Movie
• If you use a non-Olympus card or a card used for another application, such as for
a computer, the message [CARD ERROR] is displayed. To use this card with this
camera, use the [FORMAT] function to format the card.
g“MEMORY FORMAT (FORMAT) Formatting the internal memory/card” (P.24)
Additional shooting tips and information
Increasing the number of pictures that can be taken
IMAGE QUALITY Image size
Internal memory Card (128 MB)
SHQ 2816 × 2112 2 25
HQ 2816 × 2112 6 76
SQ1 2048 × 1536 8 108
SQ2 640 × 480 60 726
Remaining recording time
HQ 320 × 240 (15 frames/sec.) 32 sec. 6 min. 37 sec.
SQ 160 × 120 (15 frames/sec.) 2 min. 8 sec. 26 min. 28 sec.
Dec 15, 2007 | Olympus FE-170 Digital Camera
Record images
Quality Mode Resolution 14MB Internal Memory 256MB xD Picture Card 512MB xD Picture Card SHQ 2592 x 1944 3 images 69 images 139 images HQ 2592 x 1944 11 images 204 images 409 images SQ1 1600 x 1200 27 images 515 images 1030 images SQ2 640 x 480 144 images 2663 images 5324 images
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Internal memory
Quality Mode Resolution 14MB Internal Memory 16MB xD-Picture Card 512MB xD-Picture Card SHQ 2288 x 1712 4 images 5 images 178 images HQ 2288 x 1712 14 images 16 images 523 images SQ1 1600 x 1200 27 images 32 images 1030 images SQ2 640 x 480 144 images 165 images 5324 images Storable movie length and resolution (approximate figures). The number of movies saved is based upon the storage capacity of the xD-Picture Card and length of each movie. Quality Mode Resolution 14MB Internal Memory 16MB xD-Picture Card 512MB xD-Picture Card HQ 320 x 240 30 fps movie 20 sec. max movie 24 sec. max movie 12 min. 54 sec. movie SQ 320 x 240 15 fps movie 41 sec. max movie 48 sec. max movie 25 min. 48 sec. movie
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Fuji FinePix A800 Digital Camera Logo
187 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
