Door Lock Error---(F/DL)
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times
before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and
Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
This will essentially be the result of a failed door locking mechanism(wax motor failure). The necessary actions are to replace the entire door locking assembly. Click here to access the repair manual for your unit. This universal duet manual will guide you through the necessary testing procedure and component accessing, as well. Replacing the door locking mechanism will correct this issue.
Hi
Error F dl indicates door latch failure and to
resolve this issue you'll have to replace the door latch assembly. Also before
doing this you can leave the washer unplugged for 30 minutes and then check the
door latch assembly, if bad replace it. Please post a comment if need more
help.
Thanks
Rylee
