Hey,
I have an hp pavilion dv6000 and suddenly its dvd-rw driver (which is optiarc DVD RW AD-7561A ATA) decided not to work. when I put a dvd and click on Drive E it ejects the disc and says "Please insert a disc in drive E" and even doesn't try to read it. when it's a CD it tries to read it for a while and considers the disc as a blank 702 mb writable cd and asks write method.
my os is vista.. is it a pysical problem or something about drivers etc.?
Hi, i use an HP pavillion dv6000 with Optiarc dvd rw ad -7561a ata (light scribe). i tried installing a softwear after which my dvd rom will not work it was complaining of driver corruption. i did uninstall and re- installed th driver from the system hard drive. but it will not install correctly. my computer can also not read drive E anymore. can some one help please.
I have an hp 530 and optiarc DVD RW AD-7530B ATA is not working fine. it can not read the disc and give an error message "Please insert a disc in drive or either ask you to choose method to open" Is the lens dirty or dead?
Could be the upper/lower filters fix:
http://support.microsoft.com/kb/314060/EN-US/
Me too i also has the same error. Anyone can help us ? Please
I had this problem o both of my dv7's. When putting the disk on top of the drive spindle, make sure that you hear all 3 pins snap onto the disk. Some disks will not lock easily onto the pins, and when the drive bay is closed, the computer will issue an error message. Hope that this helps.
After trying everything and even calling HP tech service who could not find a way to fix my dv6000, I finally just cleaned the laser diode lens with a silk cloth and the dvd drive worked like new reading cds and dvds just fine. I tried the uninstall and reinstall also and even reformatted the drive with no luck. Sometimes the simplest fix is the right one.
HP Pavilion DV6000 Notebook main problem's are Power Problem, Vista Error etc..
For these problems you can visit a link by just Click Here .
For any other problems with this Notebook you can Click Here
Ho dv 6000 **** it ownt let me bur dvd at all it sucks ****
I have the same problem - but my dvd rw is pioneer......DV6000 series is messed up - so many problems
SOURCE: hp Pavilion dv6000's dvd-rw won't work
You do need to take out the high and low filter in the string in the registry. Also remove the same filters w/ a .bak extension. I own a large computer business and we see this almost daily in XP and up.
yes I too have it
the drive ejects abnormally and frequently
when I really want to eject it it does not
yes but in my case i can't see the CD ROM icon in my computer, I don't know it is due to some drivers issue or what!!!
I HVE A SIMELAR PROBLEM WITH MY DV6000. IT WILL READ SONE DISKS BUT NOT DVD VIDEO DISKS. I TALKED WITH A TECH SUPPORT GUY WHO TOLD ME IT WOULD REQUIRE A REGESTRY EDIT. UNFOURTUNATLY MY COORDLESS PHONE BATTERY DIED BEFORE I FOUND OUT HOW TO FIX IT.
WILL TRY AGAIN TOMORROW AND LET YOU KNOW. GOOD LUCK:
MARK
I have exactly the same problem. The device manager says the device is working properly but apparently it is not.
I have the same problem.
I believe the issue is hardware related because this started while I used Windows Vista. I dropped vista after several months and installed Ubuntu Linux - and the issue persisted.
same here can not play blu-ray
After installing new XP windows, CD drive suddenly mark as ROM and dont work as writeable even DVD RW. Please help
fafa
dvd drive will not work.
Hi folks,
I hav a problem with hp dv6000 (AMD Athlon) disk read error. I am unable to boot the system.plzz can u solve it......
I hav a problem with hp dv6000 (AMD athalon)....when Power on the Laptop ,it is showing disc read error and i am unable to boot the system. Plzzz can u solve it.
Thq in advance
dvd bay opens only sometiomes after restart, it doesnt burn disks and also its unable to play video dvds, sometimes it plays, maximally 5 mins after rr, and then not.
my hp pavilion dv6000 laptop will no read any disks. it just says that there is no disk in the drive.
i have the same problem.when i put a cd/dvd into my drive doesnt work.I have the same laptop iswell.
Mine just stop working too.
it wont read any disc that is in da disc driver
Will play some CD's not others. Wil play some DVD's not others...random on which will and will not play.
Mine doesnt work too, its exactly the same as ur guyses problem
I put my disk in the top tray (LightScribe Dvd SuerMulti Drive/CD-Writer) and it will not detect the disk I put in. I have tried multiple different discs, and all I want to do is burn some songs onto a CD for my friend.
