I know this is a very old thread/question. FWIW I'll add my 2 cents. I've had a Regza 42HL67 since 2007. It still looks and sounds great -- when I can finally get it to power on. For several years now when I hit the "on" button I get the blinking yellow light on the front of the TV. It blinks in series of three. It will continue to blink "forever" and the TV will never turn on.
As I imagine anyone reading this has done, I spent a ton of time researching the issue on the internet. Most common "fixes" were to update the firmware or replace one or more capacitors (I think that's what they're called). I wasn't about to try either one! The only way I've found to get the TV to power on is to unplug it then plug it back in. Sometimes it takes just once. Other times it takes several times. Very often when doing this I'll notice an electric spark. Don't know what causes the spark (I presume it's a bad capacitor/fuse/power supply/mother board, or whatever) but I consider the spark a good thing. Every time a spark is generated - and often when one is not - the TV will turn on (after cycling through two sets of three blinking lights).
By doing what I do to get my TV to turn on I don't know if I'm overriding something or, more importantly, setting myself up to someday have the TV blow up or catch on fire. All I know is that this has been working for me for some time. I hope it continues to do so.
First off....don't listen to ihatetvs, he wants you to check menu settings when your tv WON"T POWER ON.
When the power is removed from the set it is normal for the yellow LED to flash in sets of three when plugged back in. It will continue this until the tv enters "standby mode" at which time the yellow LED stops flashing, then you can power the tv on. If the yellow light (LED) continues to cycle through sets of three flashes and never comes on, you probably have some bad or borderline electrolytic capacitors on the power board, Best advice I can give the novice, if you can use soldering/de-soldering equipment, is replace ALL electrolytic capacitors on the power board. If you are NOT EXPERIENCED with replacing electronic components, STAY OUT of the tv and let an experienced tech do the work. Better safe than sorry.
I had lcd 42" over a year it is working find before , but now it has very dark picture
can y help me to find out what is a problem and how much to fix?
Make sure the power save setting is not on it turns the tv on slower > see if picture settings such as contrast and brightness are all the way up > or picture profiles are on right setting .e.g cinema is usually dark screen
I followed the steps at the following link and it worked for me. I have a 2007 Toshiba Regza 42HL67, but the firmware applies to many models as documented in the readme file at the location found via the link below. I used a 1gb SD card formatted FAT16, copied the unzipped files and folder to the card (wasn't sure if it required the top level folder or only the files under the top level folder so I copied both to the root of the SD card), unplugged the TV, inserted the card, plugged in the TV, waited 2.5 minutes, unplugged the TV, removed the card, plugged in the TV, yellow light flashed 3 times and went out. I turned on the TV and it has worked normally since last night.
http://www.benjammin.net/www/pages/techtips/Toshiba-Regza-42HL167.html
Hey i have a 42hl67 with the same problem. Before i had it plug into a surge protector and it would power on then i plug it directly into an outlet and it power on. But now i got the same issue no matter where i plug it in. Please help
the yellow lED flash 3 times but the TV never turns on.
When i plug it in the set won't power up when on button is pressed but a small yellow lit just keeps flashing 3 times,stops,then flashes 3 times over & over.Please help on maybe what the problem is .Thanks,rioconcho
same problem...yellow blinking light...won't turn back on
led flashes 3 times tv will not turn on
can't find part
