BLINKING RED LIGHT IS ERROR CODE.
1. Unplug set for a few minutes.
2. Plug back in and turn on.
3. When red power light starts blinking--COUNT THE BLINKS.
4. THREE BLINKS, pause, THREE BLINKS (ETC) IS SHORT PROTECTION AND A DO IT YOURSELF repair for some people. I have complete instructions for this repair.
5. 5 blinks, pause and 5 blinks etc is short on 140 volt line and while not as easy as 3 blink error code it points to places to look at.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
Post a comment here when you know what error code is and I will help.
REGARDS, SD TECH
can I get the complete instruction for the repair....I am having the 3 times blinking problem I have the Panasonic PT-53WX54J
We also are having the same problem, turn it on, turns off, 3 blinks, pause, 3 blinks. How can we fix it?
I need the repair instructions too. the red light is blinking 3 times. Can the directions for the fix be emailed? [email protected] Thanks for posting the help and guidance! I appreciate it.
can I get repair instructions, 3 blink error code, PT-47WX53G?
can I get instructions for repair, 3 blinking error code, pt47wx53g?
i have the 2 times blink problem please help [email protected]
I have the same problem - 3 blinks pause. Please help!!
I am having the blinking problem can you email [email protected] with a solution! thank you!
Hi, Please send me the instructions on the 3 blink error. [email protected]. I love this TV and don't want to have to replace it.
Thank you so much!!
Please send the directions. I love this tv and I hate to lose it. I have the 3 blink code and I understand it may be a do it yourself solution.
Thank you so much.
[email protected]
Hi mine is blinking 3 times [email protected]. Thanks !!
mine is blinking 3 times pause blinking 3 times could you please email something to help me fix it [email protected]
Can I please get the complete instruction for the repair....I have the 3 times blinking error. I have the Panasonic PT47WXD63G.
I need the repair instructions too. the red light is blinking 3 times. I have the Panasonic PT-47WXD63G.
do you have the fix for the 5 blink issue you talked about?
my em is [email protected] if you care to send that btw..thanks
There is no easy fix for the 5 blink---you will need to remove the light box for this set (not real hard) and check the horizontal output transistor for being shorted and also inspect C509 in same area for a crack in its case.so you got a meter? I can tell you roughly where to look for both of those parts--it means a short usually right there.
I have a PT47WX42F that is blinking 3 time too can you help please ty [email protected]
