Washing machine will fill and go throught cycle but will not drain and go into spin cycle
SOURCE: washing machine isn't spinning to drain water
suggest that the drive belt is worn and slipping under exess load solution replace belt regards billnkaym
we took apart the lid switch and the spring and another piece of copper came out and we can't figure out how to put it back in correctly. do you have a pic of what the inside is supposed to look like?
No spin no drain it is not the lid switch the pump spins ok the drive shaft connects to the motor shaft spins ok!!!! now what??
fills water and spins but doesnt drain.
i need to know how to raise the tpo to acess the lid switch for removal
For my Whirlpool Gold Ultimate Care II Top Load Washer- I encountered similar problem as this one whereby washing machine will fill and go through cycle but will not drain and go into spin cycle. I tried to adjust the height of the drain pipe and explore possibility of clogged drain pipe but it didn't help to solve the problem.
The G E washing machine fills washes and drains but when that is complete it will not refill and rinse. the green lights are on with nothing happening
fills and drains but will not wash
washes fills up won't drain or spin
