Washing Machines Logo
Posted on Aug 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
'OE' which means drain error keeps on displaying on the screen. The water inside the washer isn't draining. We've tried unplugging it and restarting the machine and running it again but it keeps on displaying OE
Anonymous
Level 2:
New Friend:
  • Expert 77 Answers
  • Posted on Aug 17, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
77
Questions
0
Helped
13622
Points
224
Check your drain lines and see if they are cloged because that is what it sounds like if not then try the pump
Wont spin keeps coming up with oe on screen what does this mean
OE error code indicates that the washer is unable to drain the water it used during the wash cycle. OE can be triggered by a kinked drain hose or a clogged drain pump filter.
LG washing machine error code OE. Error code OE on The LG washing machines simply means the pump is blocked. Presumably the water isn't being emptied properly you might have something blocking the pump.
https://www.youtube.com/watch?v=JBCodfFo6Bc&vl=en
https://www.youtube.com/watch?v=KixjQQdGNF4
https://www.youtube.com/watch?v=A4ENzr2ZR1c
1helpful
WHAT DOES OE MEAN ON DISPLAY ?
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
7helpful
3answers
I have the error code OE showing up, and the water is not draining from the washer. What should I do?
OE - drain error - 5 minute time out drain time error. check your pump/filter for blockages. Clean out the trap from the bottom, something is jamming the drain motor.
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
2answers
Getting a "oe" error how
See
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Check the drain hose for blockage. and see if the water filters is clogged. Specific instructions will vary based on your specific LG model. Most LG frontloaders have an access panel on the front for the water filter.
Washer now shows OE on progess window after i tried to wash bathroom rug. Would not spin/drain excess water and door won't open.
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn’t pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code Washing machine that has an OE error code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
9helpful
2answers
What does oe mean on my washing machine display
"OE" code in your washer indicates a Drain error. This is because the washer is not fully drained within 10 minutes. You have to check whether there is a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge.
Thank you !!
1helpful
2answers
LG WM2075CW
Drain error= Not fully drained in 10 minutes. Must be a problemo with the pump or possibly the drain is slow? clean out that filter. Check that pump for objects. THIS will help.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
6helpful
Error code OE. What does it mean? washer seems to be having a hard time draining the water
Please check the above link for a detailed picture wise explanation for the error code.
2helpful
4answers
What does the flashing OE mean? My washer is flashing OE and the water will not drain after the cycle.
OE means the drain hose is clogged. UE means unbalanced or overloaded. This is decribed in the owner's manual page 31-32. Pull the hose from the back of machine and rinse it out. Then, check the lint filter on the bottom, front left side. Put drain hose back and close lint filter. Unplug the machine, press and hold the start button for 10 seconds to reset machine computer (not the on button...leave machine turned off and unplugged while resetting computer) plug back in, put on no spin and start the machine. It should drain.
6helpful
Morning, LG WD1295FB error OE, plese advise
An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service. oe_led.jpg oe_lcd.jpg LED display models LCD Display Models Step 1: Check the drain pump filter. Step 3: Confirm that the washer is leveled properly. Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine. An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a LEVEL on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
