SOURCE: replacing door gasket on maytag neptune MAH5500BWW washer
I need to know what are the steps to replacing the door gasket, I would like to know what to take apart, and what not to take apart. Like a step by step lay out.
SOURCE: Maytag Neptune washer, model MAH5500BWW, not spinning up to speed
Open the lid. take one hand and push the tub back toward a back corner. Take your other hand and fill in the gap on the opposite corner. There should be a black round rubber strap going from the outside top of the tub to the cabinet. Once you find it check all four corners. I feel sure that you will find more than one broken. These help to keep the load balanced. It is very important that you change these as soon as possible due to after these break these machines are bad about the tub banging into the sides and cracking the outer tub. To replace the tub will run ( in my area) around $240 - $300. These straps are not hard to replace and don't cost very much. I would rate replacing them a 2 on a hardness scale from 1 to 10. 10 being the hardest.
Please rate this solution if helpful.
SOURCE: DRUM BEARINGS ARE BAD
The wholesale cost of the part is about $400+shipping. You'd pay more...
I'm in the business and mine did the same thing. When we couldn't turn the TV up loud enough anymore, I pitched it and bought a Duet!
SOURCE: need owner's manual for neptune
Unfortunately FixYa cannot provide manuals direct - members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
